Question about GE (PSS26MSRSS) Side by Side Refrigerator
The water from the dispenser tastes like plastic. Could it be the filter and where is it located?
  • 986 Answers
If there is an inline filter, replace it. They have carbon in them, which loses its effectiveness in a relatively short time. Most people go way too long without replacing the filter. Ideally you should replace it at least once every 6 months.
Whether there is a filter or not, dump the ice, and let the water on the door run for 30 minutes. You could put a little piece of flexible tubing on the spout and put a bucket on the floor. You can buy the tubing at about any hardware or building supply. Usually, a 3/8 od, 1/4 id clear tubing will fit on the spout. But sometimes you would need a 1/2 od x 3/8 id. It is real cheap. Otherwise you can stand there with a cup for half an hour.
Posted on Nov 12, 2009
huuum
  • 750 Answers
SOURCE: Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
  • 531 Answers
SOURCE: Taste of water from water dispenser has "plastic taste"
you have to flush dispense water on till taste gone
Posted on Apr 02, 2009
localwonder
  • 6784 Answers
SOURCE: can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
Posted on May 23, 2009
coupondeal
  • 76 Answers
SOURCE: ice maker has bad taste
Change your water filer
Posted on Jul 14, 2009
  • 2187 Answers
SOURCE: Drinking water has a bad taste and smell.
You will have to trace where the foul smell comes from by tracing the water line and testing the source. Check if it is before or after the filter you get the smell, if it is before the filter, you need to check if it is on the line which comes from the source or it is from the source. Most likely cleaning or probably a replacement of the part if cleaning does not help.
Posted on Sep 21, 2009
How do I clean my ice maker?
Curious, does your refrigerator have a water dispenser? How does water taste from it? Your ref. has one water supply for both ice and water. Changing filter was a good start but if it's been over a month, there's something else going on. I would look and see behind your ref. and look at the water line. I've run across a bad plastic tube that causes a bad taste. If you have a plastic one, change it out with a new one. Also, ice absorbs food odors from both the freezer section and refrigerator sections, so check your fridge for bad food. Bell green peppers are the worst, they'll leave a metallic taste. Good luck!
Sep 18, 2015 | Refrigerators
Whirlpool Gold Series Refrigerator has foul tasting water and ice.
and what does the water elsewhere in home taste like .is it city water or well water . usually you can take a sample to local health dept and they will test it free .
May 20, 2015 | Whirlpool Refrigerators
Mildew tasting water from water dispenser
Try running dome bleach through the dispenser. Might have a build up in the outlet line, after the filter.
Dec 26, 2017 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Our Sub-Zero Mdl 680F is 11 years old, and virtually for its entire existence in our house, the water and ice dispenser has been un-useable because they taste bad. The taste was "oily" almost as...
Hello
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Replace the water filter cartridge in your refrigerator if the ice tastes bad or the control center display recommends it.
Sep 07, 2011 | Sub-Zero 680 / F
There is a bad order coming from ice and water dispenser. I changed the filter but it didn't help. Smells like ''dirt''. Thanks, Linda
Replace water supply line with the plastic tubing ice maker line. It fixed mine that had a metal braided line on it that made the water taste kie rubber and dirt,, after that I tried a vinyl braided line.and it made the water taste like garden hose water.. The plastic tubing was the cure. Reply and tell me what you have.
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Terrible Plastic After-Tast in Dispensed Water (Refrig)
If indeed it is stagnant water you have to find the water source tap off of your water supply. Then trace out the routing of the feed water line to your refrigerator. Turn off the tap, remove the line at both ends. You can abandon the existing line. Reroute the new line. or you can remove the old line and follow the same route. Reconnect the tap and refrigerator ends.
Jul 14, 2009 | Refrigerators
Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Jun 23, 2009 | Refrigerators
My new Whirlpool Refrigerator the water and ice still stink
Dec 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
226 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
