Question about Magic Chef Dryers
Gas Dryer Stops after 30 minutes.
I have a Magic Chef CYG4000AWW that stops after 30 minutes of work, then I have to wait for a while until it cools down (I guess).
I have already replaced the set of Valve Coils but I still have the problem I also have cleaned the whole vent line from blower to exhaust and the dryer is blowing good.
Please help,
  • de1fo Nov 15, 2009
    When I opened the dryer again to check for lint on the motor I found out it was more or less clean, so I checked for something else could force the motor and found out that one of the drum roller was tight.
    I replaced the drum rollers and now the dryer completes the cycles.
    Thanks
  • 304 Answers
Your problem is caused by a motor overheating causing its internal overload to shut it down until the motor cools. If you truly have thoroughly cleaned all interior areas of your dryer and the vent leading from the house to the outside there are only two possible problems that can give you this failure.
  1. The dryer motor bearing is failing (tightening) causing the motor to be harder to turn. This will force the motor to draw more current to keep it running and this generates more heat than usual. The additional heat opens the thermal safety on the motor until it cools down. Motor needs to be replaced
  2. The air holes at each end of the motor are clogged with lint that needs to be cleared out. The body of the motor may also be coated with lint. Both these conditions will cause the thermal overload in the motor to open until it cools. Motor needs to be fully vacuumed.
Good Luck.
Posted on Nov 12, 2009
Testimonial: "Thanks"
The Door won,t stay closed on our gas Magic Chef Dryer
Latch is broken and needs replace or may just need reset. Probably been slammed one time too many.
Aug 07, 2014 | Magic Chef CYG4000AWW Gas Dryer
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
How do you light the pilot for gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 19, 2011 | Magic Chef CYG4000AWW Gas Dryer
My dryer isn't drying like it should. It doesn't seem as hot as it use to be and it takes forever to get things dry. I'm not sure if it's lint build up or something more. Any help will be appreciated.
heatman101';';
May 01, 2011 | Magic Chef CYG4000AWW Gas Dryer
1989 Magic Chef gas range digital display keeps beeping and says
This is a common failure in the control board. Here is an article that discusses the details.
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
We repair a lot of these at www.fixyourboard.com, so you don't have to scrap out your oven.
Jun 26, 2010 | Magic Chef Kitchen Ranges
Dryer was making noise each time it rotated. Next
HI, seems to be a busted belt here. have it replace asap if possible.
Jun 22, 2009 | Magic Chef CYG4000AWW Gas Dryer
Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
Jun 17, 2009 | Magic Chef CYG4000AWW Gas Dryer
Majic chef dryer rollers making noise. cannot figure how to get inside of dryer exposed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Magic Chef CYG4000AWW Gas Dryer
Gas dryer runs sometimes, not others.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dhjhdf
Feb 15, 2009 | Magic Chef CYG4000AWW Gas Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Dryers Logo
111 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Roderick Scott
Roderick Scott
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
