Question about Dell Computers & Internet
I'm running Vista Basic on a Dell Dimension E521. I've got two problems. When I run AOL version 9.1, it frequently reports itself as ''not responding'', then recovers.. Mostly; sometimes it just hangs. Ditto with IE Version 8. I've reinstalled AOL. I would reinstall IE, except I don't know where the bookmark file is, which I will want to copy and save. In addition, my hard drive keeps thrashing. I've gone to Services.msc and disabled Windows Search and Superfetch in an attempt to address that problem, with no success. I've also deleted my temp internet files. No luck. I should also point out that when I reboot I can get the thrashing to stop, until I open up AOL or IE. Any advice? And where's that Bookmark file?
  • jelink Nov 13, 2009
    Thank you for your comments.
    I tried booting in Safe Mode, and when I did the thrashing stopped. For the short time I was on-line the AOL/IE problem didn't occur, but I can't say for sure being in Safe Mode made any difference.
    When I rebooted in regular mode the problem returned.
    As for HDregeneration: And are you referring to HDD Regenerator? If the thrashing stops in safe mode, does it mean that the HD is not damaged, and such a pram is not useful? (I don't hear any clicks.)
  • 691 Answers
Can you run the HDregeneration program, checks & repairs the HD sectors
Also does the HD make click sounds when running, if yes, normally the drive is on its way out
Hope this helps
Richard
Posted on Nov 12, 2009
Audio install
I would say that your system should run it. Depending on what version you are trying to run, you exceed the minimum requirements (For processor).
If your able to get it up and running I may suggest that you change the acceptance for Rosetta in your firewall (Assuming that you have one running). It could be the reason that you cannot activate.
Jan 07, 2014 | Dell Dimension E521 PC Desktop
DELL DIMENSION E521 BSOD???? HELP?!
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 06, 2012 | Dell Dimension E521 PC Desktop
I have a Dell dimension e521, and when i try to open a program i get a little black box that has something to do with system 32. I tried to restore my computer back before i had the problem but showing no...
If you tried a restore. I'm guessing you can start in safe mode. If you can I would try to start in "safe mode with networking" and try to download this:
http://www.softpedia.com/get/Security/Secure-cleaning/CCleaner.shtml
You can run the cleaner and, it also has a registry cleaner. If you like it you could buy the full version but, start with the free version. It sounds like you have a registry problem. Something else that's good to have is this:
http://www.malwarebytes.org/products/malwarebytes_free
Again, you can try the free version and first, run the quick scan. Later you will want to run a full scan, it takes a couple of hours.
Jun 13, 2011 | Dell Dimension E521 PC Desktop
I got my dell dimension e521 used, when i download software to the computer it goes to the e:/ drive instead of the c:/ drive. The computer is running slow because of lack of drive space. How do i correct...
you must erase some data on the disc if you don't want to lose all because if it goes like this you will get your hard disc crashed and you will lose all important data. run disc fragment and scan disc regularly.if problem persist rather use an external hard disc for quick,safe and easy transfer
Jun 23, 2010 | Dell Dimension E521 PC Desktop
I dont know how too reboot my dell dimension E521?
Dell seem to not make a lot of computers with reboot/reset button. If Windows is already running, you can turn it off or reboot it from the start menu. What you can also do is to hold down the power button for at least 5 seconds. Usually it will turn it off itself if you hold it for long enough.
Mar 08, 2010 | Dell Dimension E521 PC Desktop
Windows Vista won't load after a full factory restore on my dell dimension e521 ?
Go into your BIO's at startup and set it to load from the CD-Rom only. Then drop the Vista disk in the CD-Rom and restart the computer. After it loads you will need to go back into the BIO's and set it back to where it was before you made this change.
Oct 10, 2009 | Dell Dimension E521 (D10E16) PC Desktop
DELL PART # DN804 For E521 computer
Hi
Dell Part # DN804 is PCI-e ATI Theater 650 Pro Combo Analog/Digital TV Tuner and it is compatible with Dell Dimension E521.
The ATI Theater 650 Pro PCI-e card is available in two form factors - Low Profile or Full Height. Dimension E521 is compatible with Full Height cards only. It is important that you ensure the you receive a full height card.
Check Installing a PCI Express Card for help installing the hardware. Next install required software/drivers.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/parts.htm#wp1080274
Mike
May 03, 2008 | Dell PART NUMBER CARD NTWK PCI TR IBM 16/4...
Computers & Internet Logo
110 people viewed this question
Alun Cox
