Question about Kodak Office Equipment & Supplies
The slides won't drop into projector fron tray
I have a kodak 4200 slid projector and The slides don't drop down into the slot on the projector
  • 2,237 Answers
The tray may be out of alignment because the indexing lever needs adjustment.
Posted on Nov 12, 2009
My kodak carosel 600 projector has a screw driver adjustment-what does that do ?
I am not familiar with a screwdriver adjustment on a Carousel 600 Projector. Are you referring to the emergency tray release in the center hub on the top of the projector?? If not, can you tell me specifically where the screwdriver adjust is located on the projector, please?? Thanks !! Jim
Feb 13, 2014 | Kodak 4200 Slide Projector
Kodak 140 slide carousel trays jam
The 140 tray with older slides and an older projector is a gamble with slide jams every time!! Slides have a natural curve that gets bigger over time. In addition, as slides age, the corners will begin to de-laminate (aka: "dog-eared" slide). Because the slide slot in a 140-tray is SO NARROW, the least little deformation of the slide from normal will cause the slides not to drop. My recommendation, given the age of the projector, trays and slides, is to get rid of those 140 trays and stick with 80-slide trays. Good Luck !! Jim
Sep 16, 2013 | Kodak Carousel 4400 Slide Projector
Mechaniism jammed.
First of all, you'll have to get the slides out of the projector. You may have to use needle-nosed pliers to remove them. Once removed, cycle the projector 3 or 4 times using the REVERSE button. The jam will be cleared. Good Luck !!! Jim
Jul 11, 2013 | Kodak 4200 Slide Projector
How to remove a Croussel from Ektagraphic AF1
First of all, make sure the LOCKING RING is in position on the tray & locked! This will prevent all the slides from falling out when you remove the tray. Next, place a quarter (or a dime or a penny) in the SLOT in the HUB of the projector. Turn the coin to release the Emergency Latch Release and lift the tray off. Flip the tray upside down. Remove the jammed slide from the optical gate of the projector (inspect it for damage - "dog-eared" slide corners cause this kind of jam) and re-insert it in the slot of the tray from the underside (now facing you). Now rotate the tray until the pointing arrow and the notch on the bottom of the tray align. At this point the tray should be back in the "Zero" position and can be re-installed on the projector. I have attached copies of Kodak instructions for this, as well. Good Luck !! Jim4d786888-c152-4bd3-b086-29e6f8e29e37.jpg409ae3e8-80fd-44c8-820b-23fd94def009.jpg
Mar 14, 2013 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
Will not load slide
Michael, Is this a Kodak projector? If so, will the tray lock in? Will it rotate if you hold down the "SELECT" button? Look at the slot in the top of the projector that the slides drop into - - is the slide lift lever in the "up" or "down" position with the projector powered on? If you answer these questions, I think I can help you diagnose your projector. Thanks!
Nov 06, 2011 | Office Equipment & Supplies
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
Slide tray won t seat on projector
Try a couple of things:
1. Turn on the projector & cycle it in "Reverse" 3 or 4 times (without the tray). Do the levers that move the tray move correctly? If so, do you have another tray you can try? If another tray works correctly, follow Step #2.
2. The 140-Tray has to be in the "zero" position for the tray to seat on the projector. Check to make sure the Locking Ring (the ring is in the center of the tray & keeps the slides from coming out) is TIGHT on the top of the tray. Once checked, turn the tray upside-down. Refer to Page 8 in your owners' manual (if you don't have one, I've made an image of the page, below). You have to make sure the plate on the bottom of the tray is lined up at the notch at shown.jauburn_12.jpg
If this helps, please leave positive feedback for me @ FixYa.com. If you need more help, please re-post!!
Apr 13, 2011 | Kodak Carousel 5600 Slide Projector
My kodak 600H projector tray will not move to the release position? any suggestions.
You may just have a slide jam (particularly common with older slides in 140-Slide Trays).
First of all, you need to get the tray removed. At the center of the tray is the hub, and an emergency tray release slot. Make sure the slide tray locking ring is in place and tight(!), then insert a quarter in the emergency tray release slot and turn, lifting the tray at the same time. One slide will probably fall out. Replace the slide in the tray with the same orientation as the other slides in the tray (markings, slide#, etc.). Then with the tray upside down (now you see why I told you to make sure the slide tray locking ring was in place and tight), rotate the metal bottom plate back to the "zero" position.
Once the tray is removed, cycle the projector 4 or 5 times, then re-insert the tray. If the problem persists, you may have warped slides (get them re-mounted or be sure to use 80-Slide Trays rather than 140 Slide Trays), or you could have a jammed slide change mechanism. And because we're talking about a Model 600H here, it may be cheaper to buy a used projector online than have it repaired. Good Luck !!
Dec 20, 2010 | Kodak Office Equipment & Supplies
I'm having a problem loading a tray onto my kodak carousel 4400 slide projector any solutions?
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Jan 14, 2010 | Kodak Carousel 4400 Slide Projector
105 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
