Question about Photography
Can I fix my cast metal tripod head it broke off . it looks like a cast iron or cast aluminum
4 Suggested Answers
  • 69 Answers
SOURCE: radian pro Gt head broke that holds the scope.
You can still order the plate that attaches the camera/scope to the head from Eagle Optics directly at this link:
http://www.eagleoptics.com/tripod-accessories/vortex/radian-pro-gt-quick-release-plate
Posted on Aug 14, 2010
Testimonial: "Thanks for the info, that's wasn't the part I need, but I think I located the part on the website link you sent."
  • 48 Answers
SOURCE: I'm An Owner Of The
Call us at 800 735-4373 regarding service on Giottos tripods. The legs are not repairable by the owner and probably not by us. Or you can send it to us at. HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Posted on Sep 04, 2011
  • 48 Answers
SOURCE: The head fell off my wife's tripod. The female
Posted on Sep 15, 2011
Is it necessary to torque the intake bolts when installing the intake manifold?
It is recommended as most intake manifolds are either cast iron or cast aluminum. Uneven torque can result in warping. Too little torque can cause intake leaks. Too much torque can cause cracking or breakage of the cast metal.
Nov 01, 2015 | Cars & Trucks
Can I use a cast iron pan on glass cooktop range
Yes you can, magnetic induction stoves are working with anything metalic.
Mar 17, 2015 | Kitchen Ranges
What arm the specs for 95 camaro lt1 350
Block and Basics
Displacement: 350 cubic inches, 5733 cubic centimeters, 5.7 liters
Block Material: Cast Iron
Main Bearings: 2-Bolt Centers and Ends (The Corvette LT1/LT4 had 4-bolt mains)
Stroke: 3.48"
Bore: 4.00"
Compression Ratio: 10.4:1
Combustion Chambers: 54 cubic centimeters
Factory Redline Rating: 5700 Rotations Per Minute
Bottom End
Piston Material: (10159437) Eutectic Aluminum/Silicon Alloy
Connecting Rod Material: (10108688) Powdered Metal
Crankshaft Material: (12556307) Cast Iron
Top End and Valvetrain
Cylinder Heads: (10168448) Cast Aluminum, 2 valves per cylinder/16 valves total, ~212 CFM flow (Impala SS and Caprice heads were made of cast iron*)
Valve Diameter: (intake- 10241743, exhaust- 12550909) 1.94 intake, 1.50 exhaust
Valve Overlap: 41*
Valvesprings: (10206040) 85 lbs, seated
Camshaft Specs (12551705): 205/207 duration @ 50*, .447/.459" lift, 117 Lobe Seperation Angle
Rocker Arms: (10089648) 1.5:1 Stamped Steel
Timing Chain: (10128485) Powdered metal link
Intake and Fuel Delivery
Fuel Delivery: Electronic Fuel Injection, sequential port
Injector Size: (17124248) 3.0gps, 22lbs/hr speed density (1992-1993), 24lbs/hr mass airflow (1994-1997)
Throttle Body: 48 millimeter twin butterfly
Intake Manifold: (12552137) Aluminum
Factory Power Ratings
92-96 LT1 Corvette: 300bhp, 330lb-ft
1996 LT4 Corvette: 330bhp, 340lb-ft
1992 LT5 Corvette: 375bhp, 370lb-ft
93-95 LT5 Corvette: 405bhp, 385lb-ft
93-95 LT1 F-Body: 275bhp, 325lb-ft
96-97 LT1 F-Body: 285bhp, 325lb-ft
96-97 WS6/SS: 305bhp, 335lb-ft
93-97 Firehawks: 315bhp, 340lb-ft
Factory LTX Camshaft Specifications**:
1992 Y-body: 205/207 0.451/0.450 lift 117 LSA
1993-1995 Y-body, F-body: 202/207 0.450/0.460 lift 116 LSA
1994-1996 B-bodies (including L99 4.3L): 191/196 0.418/0.430 lift 111 LSA
1996 Y-body, 1996-1997 F-body: 200/207 0.447/0.459 lift 117 LSA
1996 Y-body, F-body LT4: 203/210 0.476/0.479 lift 115 LSA
hope this helps
Mar 04, 2015 | Cars & Trucks
What is the head bolt torque setting
Briggs and Stratton repair manuals are available at all location ware B&S parts are sold except lowes and Home Depot. I have one in my garage the cast iron motors are different then the aluminum ones I will need the model number for the exact torque spec 60000-130000 is 140 170000-280000 is 165 Aluminum and cast Iron is 190 IN.LBS. THIS IS ALL IN IN., LBS.,
Oct 09, 2014 | Briggs & Stratton Garden
How do I know if I have a cracked head or blown head gasket
Runs like pure crap...
Loss of coolant w no latter leak..
White smoke from tail pipe..
misfires...
A fewsymptoms for u
Sep 29, 2014 | 1995 Jeep Grand Cherokee
Engine aluminum or cast iron?
it appears that the 2WD drive LT's have the iron block while the 4WD trucks have the aluminum block
Jul 12, 2014 | 2011 Chevrolet Silverado 1500
Need torque settings for the head bolts on a 1.6 ltr AE82 87 corolla
head bolts for iron cast heads is 65. for aluminum heads, its between 45-50. 1.6 AE82 is iron cast.
Aug 06, 2011 | Toyota Corolla Cars & Trucks
Spark plug blew out of motor
The spark plug blew out because it was not installed correctly and was loose. Install a new plug and do it very carefully as there may be carbon in the treads the plug screws into. Screw it in until you feel it getting tight and then turn it back. Keep turning in and out until it fully seats. Always follow the vehicle manufacturer torque recommendations, but as a general rule 14 mm plugs with a gasket style seat should be tightened to 26 to 30 ft.lbs. in cast iron heads, but only 18 to 22 ft.lbs. in aluminum heads. Likewise, 18 mm plugs with gasket style seats should be tightened to 32 to 38 ft.lbs. in cast iron heads but only 28 to 34 ft.lbs. in aluminum heads. For taper seat spark plugs, 14 mm plugs should be tightened to 7 to 15 ft.lbs. in both cast iron and aluminum, while 18 mm taper seat plugs should be tightened to 15 to 20 ft.lbs. in both types of heads.
Jan 14, 2010 | 1998 Ford Explorer
When told your car needs a valve job, what does that mean
A valve job is removing the cylinder head(s) from the engine so the valves, guides and seats can be refurbished to restore compression and oil control. A valve job may be necessary by the time an engine has 80,000 or more miles on it, or to fix a "burned valve," compression or oil burning problem.
Before we describe all the steps that a typical valve job involves, we should warn you that some shops don't necessary do all the steps. In other words, you get what you pay for. A "cheapie" valve job might skip a lot of things that saves you a few dollars in the short run, but may end up costing you a lot more in the long run. So look for a shop or service facility that does quality work.
A valve job typically begins by disassembling, cleaning and inspecting the cylinder head. Cast iron heads are "Magnafluxed" to check for hairline cracks. This involves applying a strong magnetic field to the head and sprinkling iron powder on it. Cracks disrupt the magnetic field and attract the iron powder, making invisible cracks easy to see.
Cracks are bad news because they can leak coolant into the combustion chamber damaging the cylinders and/or causing the engine to lose coolant and overheat. If cracks are found in any critical areas of the head, the head must either be repaired or replaced. Cracks in cast iron heads are most often repaired by "pinning" (installing a series of overlapping threaded pins). Cracks in aluminum heads are very common and can often be repaired by welding.
If a head has been repaired (pinned or welded), most shops will usually pressure test the head afterward to make sure there are no leaks. Some may also apply a sealer compound to the inside of the water jackets as added insurance against future leaks.
Once the head passes this point, it is also checked for flatness. The surface of the head must be flat to seal the head gasket against the block. Excessive warpage, roughness or any damage can cause the head gasket to fail. If the head exceeds the maximum allowable out-of-flatness specs, it must be resurfaced or replaced. Usually there's enough metal in the head to allow for a certain amount of resurfacing. But on many import aluminum cylinder heads, the amount of resurfacing that's possible is minimal.
Overhead cam aluminum cylinder heads are often found to be warped (usually the result of overheating). If the condition cannot be corrected by resurfacing, the head can often be straightened by heating it in a special oven and then bending it until it is straight.
Next come the valves, guides and seats. The guides are checked for wear. They're almost always worn, so they either need to be replaced, relined or knurled (a process whereby grooves are cut into the inside diameter of the guides to decrease the bore size). Few shops knurl guides anymore. Most install new guides, guide liners or bore out the old guides to accept new valves with oversized stems. Aluminum heads have cast iron or bronze guides that can be replaced but most cast iron heads do not.
If the valves are to be reused, they will be inspected, checked for straightness then refaced. Many shops automatically replace all the exhaust valves to reduce the risk of failure (exhaust valves run much hotter than intakes and are much more likely to fail).
The seats in the head are either cut or ground to restore the sealing surface. If a seat is cracked or too badly worn to be refaced, the seat must be replaced. If that isn't possible (as is the case on many late model cast iron heads because the casting is too thin), then the entire head must be replaced. All aluminum heads have hardened steel seats that can be replaced.
The valve springs are all inspected and tested to make sure they are still capable of maintaining proper pressure. The spring retainers, keepers and other hardware is likewise inspected. Any worn or damaged components are replaced. New valve guide seals are always used.
The valves are then installed in the head and shimmed to restore proper valve height. This is necessary because machining the valves and seat alters their dimensions. Valve height is important because it affects valvetrain geometry and guide wear. If it is an overhead cam engine, the cam is also installed and the valve lash adjusted prior to returning the head to the customer
Sep 18, 2009 | 1992 Toyota Tercel
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Photography Logo
64 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
