Cooling shutting off green light flashing!!!!! its hot here in australia
    President:
  • 1,515 Answers
Hi, Not knowing what kind of a/c unit you have I can give you some things to check out that may get you back online.If this is a split system, indoor and outdoor unit, always check for power first. Check the outdoor unit as it is on its own high voltage box.It sounds like it is a ductless split system, controlled by a remote. If you have a manual, try going through the trouble shooting section of the system.This Heat may have shut the outdoor unit off, the compressor due to high head pressure? If the fan is running, listen for the compressor and see if it is on also. You can kill the power to the outdoor unit, and take a water hose and wash the dirt from this coil, being careful not to bend the fins.If it is off on high head, this will bring it down and hopefully run and cool for you.Please get back to me with more Information on the type of system that you have if I haven't got it right.Try doing what I have recommended also, step by step. Sincerely, we can get this up and running for you, if you get back to me. Good Luck,
Shastalaker7
Posted on Nov 12, 2009
DLP 65 in. wont turn on. Lights flash . Red light first followed by 9 green lights flashing-then shuts off.Repeats this pattern.My lamp is foggy but not blown. Is it the lamp? Lamp is 1 yr old.
While i don't recall that particular pro lemme alot of Toshiba sets had an issue with the ballast boars. Basically over time the solder connection s get hot and cool so much that the joints Crack and breal. The ballast board may need to be resoldered. If you choose to try this yourself...be advised there are very high voltages inside a tv that can seriously hurt or kill you.
Jul 07, 2016 | Toshiba Televison & Video
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
Shutting off green light flashes
It means that the vacuum is too hot or too cold
Feb 02, 2014 | Dyson DC44 Animal Cordless Vacuum
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
Sony 57 projection flashing blue green and shuts off blinks 8
if its hot cool it if that isnt it reset it by unpluging it and holding the power button while unpluged
Mar 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Red flashing light on ps3
When the light flashes red and you ALSO see the green light on too this indicates that the system is getting hot and you need to switch off and let it cool down.
if you switch on get the beeps see yellow light briefly then flashing red only this indicates failure.
The system has shut itself off to stop further damage ..... supposedly caused by getting hot .. maybe fan failed .... only thing that can be done is to contact Sony for repair or replacement.
I know this post is old but thought the info could help others ...... I hope you returned your PS3.
Sep 27, 2008 | Sony Playstation 3 (PS3) Console
Light
I don't know Samsung's warranty policy for Australia so I'd email them right away. It could be an input voltage problem. It could be heating up components in your equipment causing it to shut down and reset when it cools off. As the green light is not even coming on may be an indiction of this. So I'm guessing you are currently shortening the life of your equipment. Rich
Sep 20, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
