Question about Alpine CDA-9813 CD Player
No Sound I am getting an error message on the screen of my cda 9813. The unit lights up fine and all of the buttons work but there is no sound. There is a cd in the unit and I am unable to eject it. I have tried to reset the unit but it does not work. All of the wiring seems to be fine. Anyone have any ideas?
  • 5 more comments
  • lyxfizzyl Jan 09, 2008
    I have the same exact problem... it just started today.
  • WINGNUT55 Jan 22, 2008
    I have a CDA9813 as well, and mine has the same problem. When I turn
    on the ignition in my vehicle, sometimes the unit works, and sometimes
    it doesn't, even though all the buttons and display light up as
    normal. Plus whenever that happens, the CD will not eject. I need to
    turn the ignition on and off to get it to work. I have not gotten an
    error message yet. I just replaced my unit tonight with a new cheap
    Sony unit. I would like to try and get mine fixed. I suspect there is
    a cold solder joint somewhere in the faceplate.
  • alberto mora
    alberto mora Feb 25, 2008
    i have the EXACTLY problem with my cda-9813, please help us!! of if someone know some repair service online for this proble let us know, Thanks
  • sav0320 Apr 23, 2008
    Man, my 9813 is doing the same thing as described. No CD eject, no sound from V-Drive or pre-amp. Everything else functions fine.
    I have a spare 9827 sitting around, but I need the Bass Engine Pro capability to tune this system.(I'll never buy another Alpine without the BE Pro). My 7897 in the Mustang has never had an issue (better not at $600).
  • Anonymous Jul 29, 2008
    same thing no tilt options work or anything the sound is gone and the cd is stuck inside the unit and will not eject anyone have a solution
  • Anonymous Jan 12, 2009
    same problem, except mine will display an ERROR message after a few seconds...If I repeatedly turn the unit OFF and back ON, it will start working - I thought maybe it was the cold weather, but it does it even in Spring -
  • Anonymous May 19, 2009
    no sound either, cd will not eject,,,,
    Problem Solver:
  • 6 Answers
Everybody here got took by alpine. get together form a class action suit.
Posted on Dec 31, 2008
Cda 9813 alpine say ERROR
the problem is with the reader.
Feb 25, 2008 | Alpine CDA-9813 CD Player
Alpine cda-9813 no power
You check the radio fuse in the fuse panel?The wire connections are right? Check the Owners Manual for other details or troubleshooting: ALPINE CDA-9813
Hope helps.
Jan 29, 2010 | Alpine CDA-9813 CD Player
I have a CDA-9813. all controls are lock up with the exception of the source button which will change from CD and turner but you are not able to hear or change the channel. The tilt does not work or you...
You may just got a bad control logic board our a bad service capcitor inside, You may want to have it looked at by a Technition in your area I am sure you can come to a solutin to this problem.
I take part of my day answering free questions hopeing you will give a good rating if you could that would be great. Thanks
Aug 19, 2009 | Alpine CDA-9813 CD Player
CDA-9813 No sound, will not eject CD
There is a very tiny dot located either on the actual face of the alpine head unit or on the front plate of the radio once the face has been removed. Once you find this dot(if on the actual face) you need to make sure unit has power turned on and witha tiny needle or pick you may push this reset buton in for about 2 seconds. The face will automaticaly fold down and the disk will eject itself. Once this is done do not place the same disk back into the unit. Hope this solves your problem
Jun 09, 2009 | Alpine CDA-9813 CD Player
No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Dec 12, 2008 | Alpine CDA-9855 CD Player
ALPINE CDA 9813
make sure that the acc and ground are hooked up right. acc has to be 12v. if you hooked it up to any other wire it will work until you(turn it up) draw more power than the wire you have it connected to can produce. or you have speakers that are faulty or too big for the alpine head unit.
Sep 18, 2008 | Alpine CDA-9813 CD Player
Alpine CDA-9813 CD Player problem keeping the power stay on
i have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
May 18, 2008 | Alpine CDA-9813 CD Player
No sound
The stereos audio amplifier IC is damaged.
May 07, 2008 | Alpine CDA-9813 CD Player
Alpine CDA-9813 soundless
on your cd player hold down the f button for few sec. It will take you to the setup screen. You will then scroll till you see POW-IC make sure it says ON if it is OFF then only your subs will play and no door speakers.
Sep 15, 2007 | Alpine CDA-9813 CD Player
Alpine CDA-9813 CD Player Logo
335 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
