Im haveing a problems trying to start my washer,wen i start it it says door unlocked?
  • 155 Answers
Close the door if fault comes up push on door if the door latches and starts have a look at door latch look for raised edge if so sand or cut flat try again if works good if not door lock could be faulty and may have to be replaced access this by removing top turn of power first hope this was helpful let me know
Posted on Nov 12, 2009
When I press start nothing happens then "door" flashes on screen even though the door is definitely closed
have you tried push the door in harder once u have turned it on my grandads old hotpoint washer was like this and wen used to jus push the closed door a liltte and it started
Dec 03, 2011 | Hotpoint Washing Machines
Hi i have a samsun top loder washing machine wen i prest sart it wont start keeps beeping and i just displays DE how can i fix this
Hello
This code means door error.There is a problem with your door magnet or switch not making contact or closing the loop to allow washer to start.
Try cleaning off the magnet if there is one,or checking that the switch itself is not loose or broken.
Please unplug machine before doing any of the above.
Apr 01, 2011 | Washing Machines
How do you unlock the door
The problem is due to faulty door switch . If the switch is bad, washer will remained lock and the washer won't run. Try unplugging it for an hour, press and hold start button for 5 seconds, release, wait 10 minutes, and plug back in. This method resets the washer and unlocks your door.
Thank you !!
Jun 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code 13 on my 5oo plus series washer, it will not coplete the load or unlock the door, im afraid the clothes are going to start smelling
On the small round disk at the bottom right...insert a small round pointed object into the hole and push gently, while do this rotate the disk clockwise. This will allow you to remove the disk. Look inside and there will be a slender plastic rod next to the drain clean out. Pull down gently to manually unlock the washer door. Unfortunately that will unlock the door but probably not fix what caused the issue in the first place.
Jan 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wont start
hello, i hope this is just a vehicle security issue! try (out of vehicle) , locking and unlocking driver door with key, get in and try to start, ........will any other lights or instruments turn on?
May 22, 2009 | 1998 Volkswagen Jetta
Door would not unlock - got an error code f-22 what does that mean?
your door switch may be going bad.try pushing the door in and hit drain spin and if that works then it will unlock.I need to know what code is flashing to help further.hope it helps.
Mar 05, 2009 | Whirlpool WFW9200S Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung washing machine reset code
i have samsung
6 kg WA80HAG silver nano
dear'
plz help me to reset washing
machine
thanks
Mar 18, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
