Question about Olympus FE-280 Digital Camera
Broken battery contact??
I'd like to see a diagram of the inside workings of an Olympus FE-280 digital camera. I dropped the camera. It turns on then immediatley turns itself off. It appears that the center battery contact is missing but I'm not sure of what it's supposed to look like.
  • 479 Answers
SOURCE: blurry pictures
Try going thru the menu and reset camera. If not then repair
Posted on Aug 20, 2008
  • 479 Answers
SOURCE: I got sand in my camera
send to repair... a camera repair person should be able to clean and get your lens back on track
Posted on Sep 03, 2008
SOURCE: my olympus fe 210 has the lcd screen broken, I would like to fix it by myself, how to replace it?
Hello Fabio,
You can find the replacement LCD screen for Olympus FE210 here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Categories/Olympus
Posted on Jun 01, 2009
MNfisherman
  • 11896 Answers
SOURCE: When I switch on my camera the lens just keeps
The firmware will need to be upgraded. It is a fault with all digital cameras these days. Company will repair it for $50
Posted on Jul 10, 2009
  • 4090 Answers
SOURCE: OLympus FE-280
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the service online ++++Thanks for using FIXYA
Posted on Sep 23, 2009
Battery button broke
Well, you might try a jeweler to do the tiny work inside your camera. The other place, besides the Factory, would be a Camera repair place. Look in your local phonebook.
Jan 23, 2012 | Olympus FE-280 Digital Camera
My cameras lens are broken.what is the price of the original lens
You can get a replacement one from Ebay for $30.
http://cgi.ebay.com/Olympus-FE-280-Digital-Camera-LENS-ZOOM-ASSEMBLY-/220693961161?pt=Digital_Camera_Accessories&hash=item33626299c9
Jan 05, 2011 | Olympus FE-280 Digital Camera
Card cover open fe 280
You can fix it with a small piece of tape inside the unit where the memory card goes. Just look inside for a sensor or a small button, and try pressing it down yourself. If that works, then maybe a slip of tape over that spot would fool the camera into thinking the cover is closed. If this is not fixing your problem take your camera to Olympus as this problem involves some built in mechanism troubleshooting.
Thank you !!
Jun 18, 2010 | Olympus FE-280 Digital Camera
Dropped in water, won't turn on
Was the camera on at the time it fell in the water?
Apr 24, 2009 | Olympus FE-280 Digital Camera
Jul 02, 2008 | Olympus FE-280 Digital Camera
Olympus FE-280 Digital Camera problem
I had the same problem.
First the obvious, Is your charger actualy charging? Have you tried another Battery?
Sometimes the charger led turns green, when it actualy never charged the battery.
Jiggle the battery around to make sure it is seated securely. If in doubt find a friend with a Volt meter (VOM ) and check that the battery voltage is 3.7v to 4.0v when fully charged.
Assuming that you now have a fully charged battery. it's time for a little house cleaning. Use a Q-tip and Isopropal alcohol .99 cents a bottle. (Not Rubbing, it contains lanolin).
Gently clean the contacts on the charger and the battery. You dont need a lot. A little dab'l do ya. You can also clean the contacts on the charger with a pencil eraser if they look a little corroded.
Now it gets a little more fun. Look down inside the camera battery compartment and make sure the spring contacts are sticking up far enough to contact the battery, also make sure the battery eject spring is not bent and interfering with the contacts or the battery.
If you feel confident, gently, very gently, clean the contacts in the camera.
Only wipe towards the center once or twice. If you wipe the other way, you will have
cotton fibers wrapped around the contacts. not good ! If you do not feel confident cleaning inside the battery bay, Dont!....... send it to Olympus. I hope that does the trick for you. Nice taste in cameras by the way. Sumthin
Mar 31, 2008 | Olympus FE-280 Digital Camera
How to recharge battery of Olympus FE-280 Digital Camera
When you purchased the camera, there should have been a charge in the box (you got a lithium-ion rechargable battery with the camera, no?). You put the battery in the charger and plug the charger in the wall.
Mar 12, 2008 | Olympus FE-280 Digital Camera
Automatic zoom
recharge battery after full charge install it what are changes ,does it works? If not clean battery teminals.
Dec 26, 2007 | Olympus FE-280 Digital Camera
Olympus FE-280 Digital Camera Logo
22 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
