Question about Teac Floppy Drive 235HF Internal Floppy Drive
I have a floppy disk that I have been able to access until recently. Now I get an error message that says the disk is not formatted. Also If I try to format it, all the information on it will be erased. What do I do?
    President:
  • 216 Answers
Recently had D1 color screen. Now I cannot load floppies or disks. I keep getting error messages. I did re calibrate the machine. Any suggestions is appreciated. Thx
Sound like your floppy disk drive has failed. However, if you have a vacum that will blow, try blowing air into the disk drive in case it has some thread or other debris in it. Good Luck!
Jan 05, 2015 | Sewing Machines
Downloading problems
How are the floppy discs formatted?
Mar 12, 2008 | Audio Players & Recorders
I have a Teac USB portable diskette drive, N533. Until recently, it has worked okay. However, it has started not opening any diskette I put in and instead a message appears that the disk needs to be...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Apr 28, 2011 | Teac IBM USB Portable Diskette Floppy...
When I try to open files recovered from a floppy disk, I always get the error message "Unknown File Format." Is there anything I can do?
try using backup and restore
click on restore and then click on advanced restore
select the path and click on restore
Feb 08, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
I am now unable to access a floppy disk that I had been able to access for years. I now get an error message that tells me the disk has no ID address mark. How do I fix this?
Try changing the stting switch on the disk. I think it is for formatting or something like that. Try moving it to the opposite direction and then put it in your computer again ;) Good Luck
Nov 12, 2009 | Teac Floppy Drive 235HF Internal Floppy...
I am unable to access my teac FD-05PUW usb floppy disk disk drive it come up in my computer as disk B but when I try to assess the drive it tells me the disk is not formatted but when I attempt to format...
Solution 1.
Try using the Installation CD or Utiltity CD that came with your drive to format it.
If theres a Utility CD then install it on your computer and try formating it from the utility application.
If the windows error messages still persist then try formating it with the windows default options or NTFS option.
Apr 26, 2009 | Teac FD-05PUB External Floppy Drive
NOT FORMATTED
The error means 3 things:
1. Files format of the files saved on the Floppy disk is not readable on the OS or does not comply with the file format of the OS. So you really need to format it.
2. The floppy disk is brand new and you need to format it first.
3. The floppy disk is not working. Try a known working floppy disk.
Oct 12, 2008 | NexxTech USB External Floppy Drive (NEFD2)...
Floopy drive
Sounds like you have a bad floppy drive. If you are unable to read a disk and it wants to format it so it can read it try letting it format a floppy with no data on it or with floppy you don't care about. If it can format and you can read and write to it, then bad disks. If not then you know you have a bad floppy drive. Replace and enjoy.
Feb 12, 2008 | Computers & Internet
FORMAT ERROR
You may have a bad floppy... Just like floppy drives in PCs sony floppys do go out. If you search around as I did (sorry don't remeber the link) you can find diagrams on how to replace the floppy and they are available for sale! I think we found some for $25 per. Good hunting!
Dec 26, 2007 | Sony Mavica MVC-FD200 Digital Camera
Teac Floppy Drive 235HF Internal Floppy Drive Logo
137 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
