Question about Dell Computers & Internet
Cannot boot laptop on startup I get the message ''MBR error 3''
  • 50 Answers
1) Boot from XP / Vista install dvd.
2) when prompted select "repair console" (or what's it called)
3) in the dos window type "map" -> you should see the list of your disks
4) now type "fixmbr [device_name]" where "[device_name]" is what the "map" command found for you and should be your primary drive.
Warning! This is a "in deep" operation and may cause data loss.
If you are not sure what you are doing - have a pro do it.
More info at:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/bootcons_fixmbr.mspx?mfr=true
Posted on Nov 12, 2009
Mbr 1 error insert floppy press any key to boot
When you boot, there might be a key, like F11 that will let you reinstall; look for the option during startup.
Better yet, do a Google search on "Fix MBR". Look for a USB or CD burn solution that you can download to a working computer. You might then have to press F12 during boot to change the boot device to the USB thumb drive, or CD before it will run.
Malware could have taken the system down, an update to the system, or software.. it's also possible the hard drive is damaged. Did you happen to drop or bump the laptop about the time it was shutting down?
You can pres F8 (or F5) key repeatedly during startup and cursor down to "Start in Safe Mode with networking" option, and press the Enter key, but I doubt you'll get that far if the MBR is damaged.
Aug 05, 2012 | Dell LATITUDE Computers & Internet
MRB Error message on Gateway laptop 6510GZ. how can we resolve?
First of all I'm not this smart. I found it and pasted it here for you from:
http://www.pcpowerguide.com/windows/damaged-mbr-error-message/
They get all the credit!
MBR is the acronym for Master Boot Record. The master boot record is located in the boot section of your hard drive, which is the first sector on the first platter. When you boot your computer, the master boot record tells the computer's BIOS (Basic Input Output System) where to find the bootstrap code for the operating system.
So if the MBR is corrupted, the BIOS can't find the operating system and you can get error messages like the following ones:
  • Missing operating system
  • Error loading system
  • Invalid partition table
Looks pretty scary, doesn't it?
However, it is usually not that hard to fix a corrupted MBR and usually the rest f the hard drive is just fine and will boot normally once your fix the master boot record.
What Causes Damage to the MBR? A lot of things can cause damage to the MBR such as viruses designed to corrupt the boot sector. Some of them copy the original MBR to another file. Others do this by overwriting the MBR with virus code. In fact viruses and malware are one of the most frequent causes but, any file can become corrupted especially files that are accessed as frequently as the MBR.
How to Fix the MBR The stapes to fix the MBR are slightly different in the different versions of Windows. So I will cover them separately.
Windows XP
  1. Insert your XP installation disk in the CD-Rom and reboot the computer
  2. When asked, press any key to boot from the CD
  3. When you get the Welcome to Setup screen, press "R" to open the repair console
  4. Enter your administrator password when prompted
  5. At the command prompt, type fixmbr and press enter
  6. When a new command prompt appears, type exit
  7. Remove your installation CD
  8. Restart the computer
Windows Vista
  1. Insert your Vista installation disk in the CD-ROM and reboot the computer
  3. When you get the Install Windows screen, fill in the language and location options and then click Next
  4. Click on the Repair your computer option
  5. Select the Windows Vista operating system and click Next
  6. Enter your administrator password when prompted
  7. In the System Recovery Options, select Command Prompt
  8. When a command prompt appears, type bootrec.exe and press enter to fix the MBR
  9. When a new command prompt appears, type exit
  10. Remove your installation CD
  11. Click Restart in the System Recovery Options window
Windows 7
  1. Insert your Windows 7 installation disk in the CD-ROM and reboot the computer
  3. When you get the Install Windows screen, fill in the language, Time and Keyboard Input options and then click Next
  5. In the System Recovery Options, select Command Prompt
  6. When a command prompt appears, change to the boot directory
  7. Now type bootsect /nt60 SYS and press enter to fix the MBR
  8. When a new command prompt appears, type exit
  9. Remove your installation CD
  10. Reboot the computer
Aug 14, 2011 | Gateway 6510GZ Notebook
Non-system disk or disk error Replace and strike any key when ready
Bad hard drive. The PC can not find an operating system. (e.g. Windows)
If you are lucky, you may be able to recover it by repairing the MBR or Master Boot Record.
If you have Windows NT / 2000 / XP, you can boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix MBR.
Or just run Repair Windows from the Windows CD/DVD..
If you boot up on the CD and the hard drive is not recognized then its likely dead and will need to be replaced.
Jul 12, 2011 | Computers & Internet
Toshiba tecra M3 wont start. Upon startup it shows a black screen and says problem loading operating system
download form bootdisk.com "XP Boot" and burn to cd in an .iso (bootable) format.
boot from the cdrom (you may have to go into BIOS and look for a "boot priority" option to allow you to boot from cd, to acess BIOS, hit "escape" and then either "F1" or "F2" as soon as you turn it on). run fdisk /mbr from the XP Boot cd. with this tool, try to repair the mbr. if that does not work, you need to use this tool to erase the mbr and reinstall windows.
Nov 06, 2010 | Toshiba Tecra M3 Notebook
Vaio operating system not found.
first check that your hdd is detecting by your laptop.
i think you have removed mbr master boot record from your hard driver the soution is to create master boot record in your harddrive by using mbr commands.
May 06, 2010 | Sony VAIO VGC-LV110N PC Notebook
Disk read error occured
If not give it a go and do a repair if needed again!
1- You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
2 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
3- or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!!
Mar 26, 2009 | Dell Inspiron 1525 Laptop Jet Black
How to remove a bootloader from MBR
Boot from windows startup disk (CD or floppy), enter command prompt mode. Make sure you have fdisk program. Then run `fdisk /mbr` to restore your MBR (Master Boot Record).
Dec 25, 2008 | Red Hat Enterprise Linux ES 3 Standard...
MBR error
MBR = Master Boot Record
It could be that you have a bad hard drive.
Yes, test the CD in another computer (just abort the install after you establish it is ok).
It could also be that your BIOS may be having a problem (the can boot from CD).
How old is the laptop?
Oct 18, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
