Question about Samsung BlackJack Smartphone
Power jack within phone is loose or broke cannot charge it
I have the same problem in my BlackJack II. Any solution yet? IFor a few weeks I've MacGyver'd a rubber band around the charger ro hold it in but that no longer works either.
Posted on Dec 17, 2009
Acer aspire one charging port loose
If I recall this model line uses a fixed DC power jack directly soldered to the main board. When they become loose, you can visually inspect the jack itself (without the cord plugged in), and use a pen or probe to see of the center peg is excessively loose. The common result is the solder connections have been broken between the DC jack and the main board. Often the jack itself needs to be replaced (involving complete disassemble, de-soldering old jack, cleaning, repair PCB if needed, and re-solder new jack in place.
TIP - if it is not charging, remove battery, and gently put pressure from different angles with the power cord plugged in, and try to turn it on. If it turns on with pressure from a specific angle, it would indicate the DC jack is indeed loose, and likely needs to be replaced. It works becomes the pressure is making the electrical contact that has other wise been broken. ALSO, if it turns on easily, yet losses power at certain angles, its a similar issue.
TIP2 - If it still indeed charges regardless of the angle, and does not lose power, it may be a "Modular" DC jack, meaning the jack connects to the main board through a wire harness, and is less prone to breaking the electrical contacts, and the jack is simply loose inside it's retaining clips/slides. Minor disassembly and hot glue are quick fixes for this since usually the plastic clip/slide in the chassis have broke.
GOOD LUCK! :)
Dec 06, 2013 | Acer Aspire One PC Notebook
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 19, 2013 | Motorola Mobility Motorla MOTXT912 DROID...
The charging port broke of from my htc evo 4g phone.
First Option:
Second Option:
Sep 10, 2012 | HTC EVO 4G Smartphone
My Samsung Galaxy when it is unplugged , seems to lose battery constantly and within a minute of being charged the phone hits red althoughthere is no charge at all, What would you suggest i do? no charge...
First Option:
Second Option:
Aug 14, 2012 | Cell Phones
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
I have a Dell Inspiron 1525, I purchased a new battery and a new charger and I still getting the message that it's plugged in but not charging. What could be the problem?
Your problem is that the power jack in your actual laptop is loose. it may not seem like it is but one of the 3 connections (positive, negitive, data) that hold the jack to the board broke. In this case its the data connection that tells the laptop what kind of adapter is plugged in, and dell laptops wont charge without knowing that. Solution- 1.Pay someone to replace the power jack 2. If you can solder, by a new jack (around $5) and disassemble the laptop and replace it yourself.
Jan 13, 2011 | Dell POWER SUPPLY Power Supply
I have an old compaq evn n610c. I had some problems with it for a while where I had to wiggle the power cord a little to get it to power on with the cable. That worked for a while and then one day it...
Hello,If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack((DC jack)) is broken or loose.
If the power jack is broken you can replace it if you know few things about soldering;)
If the power jack is not broken but loose (not making good contact with the motherboard) you can re solder the old jack without replacing it with a new one.
Jan 20, 2010 | Compaq Evo N610C Notebook
W800i not charging
Since you've got a new charging unit, you may need to try using different battery. If same problem occurs, then plug the charger to the phone and slowly wiggle the charger to see if the power jack is loose.
If everything looks okay, then there's a loose connection inside or a bad IC that needs to be replaced. And you may need to contact the manufacturer for repair.
Have a great day!
Oct 18, 2009 | Sony Ericsson K800i Cellular Phone
After charging the phone, there is no dial tone. The phone jack works. The battery is brand new.
the jack can be loose not allowing to charge it
for eg. u keep it for say 12 hours out of which it charges only for an hour or 2 you should check the jack
Sep 04, 2009 | Lands Phones
Samsung BlackJack Smartphone Logo
59 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
