Restart function will not work now!? If I hit restart it ends up on a blank screen and I have to cold boot. What can I do??
    Problem Solver:
  • 9 Answers
If you has a cd please reinstall and choose upgrade system ,,,,
Posted on Nov 12, 2009
When i power up my Acer M3400, everything loads then after the 'welcome' windows part the screen goes black and i can only see the mouse cursor? I tried to restart but nothing happens. It keep
Not sure, but try loading Safe Mode by pressing F8 during boot and lowering screen resolution. In Safe Mode you can even run System Restore. It load to a previous date that you choose.
Jan 11, 2013 | Acer Aspire M3400 PC Desktop
For Atheros PCIE Ethernet Controller... check cable connectionPXE-E63:error while initializing the NICPXE-MOF:exiting intel PXE ROMNo bootable device-insert boot disk and press
Sounds like you are trying to boot from a lan or someplace other than your hard drive. Turn the computer off then turn it back on and watch the screen for which key it says to hit to Change the Boot Order or Boot Sequence then hit that key. You have to hit the key when you see the message or it will not work and you'll have to reboot to restart the process. Select the Hard Drive as your boot source and then see if it boots up all the way. If it does, you will have to do this each time you start the computer unless you make a permanent change to the boot order or boot sequence.
To make the change permanent, turn the computer off and restart it. Look at the screen for which key it says to hit to get into the Bios or System Setup then hit that key. You have to hit the key when you see the message or it will not work and you'll have to restart. Once you get into the Bios or System Setup look for the Boot Sequence Tab or Settings and go change the boot sequence or Boot Order. Make the cd drive 1st, and the hard drive 2nd. This is the normal boot order or boot sequence. Just make sure when you boot the computer you don't have a music cd or movie dvd in the drive or you'll get an error because the system will try to boot from the cd/dvd drive 1st.
Jun 10, 2012 | Computers & Internet
How restart laptop using f bottons
You don't restart a laptop using the Function Keys (F1 thru F12). You restart the laptop by hitting the power button. The function keys will allow you to boot the laptop in SAFE MODE if you repeatedly hit the F8 key until you see the Safe Mode option after you hit the power button. Function keys will also allow you to change the boot order, go into the BIOS or Setup to change things also. You need to state your problem as to what is going on with your laptop.
Mar 19, 2012 | Computers & Internet
My screen will just be black after when it should go to the blue login screen. how do i fix it?
In the BIOS setup under Video choose the built-in adapter and no Dock video. Save and Exit BIOS setup. The system reboots. If it does again doesn't give you the blue login screen, press and hold the power button to shut it down. Restart it again and immediately after the Dell screen press and hold Function & hit the function key with the display on it. I think it believes you want your primary video to go to an external monitor. This should correct it if that is the cause of your boot-up blankness.
Dec 15, 2011 | Dell Latitude D600 Notebook
My computer will turn but it only shows a blank screen with a flashing dash in the top left hand corner. Can you help?
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language, then select the option "Startup Repair". Click on it, and let it repair the startup. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
Chadlnrd
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Feb 28, 2011 | Computers & Internet
HP 6910p will not boot upon restart. If the
seems like there is some s/w glitch in it. try to create a new admin a/c. hopefully it will fix the problem.
Apr 28, 2010 | HP Business Notebook 6910p Notebook
The laptop boots to the DVD function and shows nothing but movies
you need to reconfigure your startup options in bios when you restart hit f2
Feb 03, 2010 | Toshiba Satellite M105-S1021 Notebook
Problem on booting and restart:
You have to boot up in Safe Mode or "Use the last know good configuration"
Before anything comes up on your screen you must hit either F8, F4, or F6 to intercept the operating system boot.
It will give options like I mentioned. If your machine worked recently, I would try the "Use last known good configuration".
ANd if youset up a retore point. You might want to go back to it. and restore the system to an earlier time
Mar 22, 2009 | HP Computers & Internet
Dell 1501 inspiron laptop blank screen
Have you installed any application/program prior to the blue screen? Most blue screen causes your system not to boot to your operating system anymore. It is possible that your hard drive is crashed due to a virus infections or spywares. Incompatibility and corrupted system registry may affect your system to have blue screen as well.
You may try the following steps below.
1. Restart your computer. After you pressed the power button to restart. Keep on tapping F8 key on the keyboard on and off.
2. Boot advanced option will show up on the screen. You may boot your computer to the following option.
a. Last known good configuration
b. Safe mode with Networking.
If Safe mode w/networking works, restore your computer to an earlier using the system restore features.
Keep me posted.
Regards,
jeff
Oct 18, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
