Ricoh aficio2232c with fax problem: display please wait and stop there. when I disconnect the HDD, it works, but when I copy, Black letter comes with cyne how can I fix those problem? thanks
  • 2 more comments
  • goldcopy Nov 12, 2009
    I do not think so , when I disconnect the Hard disk driver on printer controller board, it works, but it can not scan and duplex copy.
  • goldcopy Nov 13, 2009
    Have you tried to format it ? I did it ,but same problem.
  • goldcopy Nov 18, 2009
    how can restore the HHD? THANKS
  • goldcopy Nov 25, 2009
    when I turn on the machine, it stop there ”wait“,thanks.
    Scholar:
  • 159 Answers
Does this only happen when you are trying to fax? Or is this when you print from your computer?
Posted on Nov 18, 2009
    President:
  • 1,653 Answers
Sounds like you need to replace the HDD and restore the system software and applications on it.
Posted on Nov 13, 2009
  • 4,924 Answers
If it wirks without the hdd ..than save whatever ya have on it ,,,and format it ...maybe it has errors or something ..if its connected to a computer reinstall the driver ...
    Guru:
  • 830 Answers
Hello and thank you for using Fixya's services.
It sounds to me like the chip on the cartridges are dirty. You can clean these by pulling out the ink cartridges and swabbing the chip on the bottom with a little alcohol.
Dirty cartridges would relay a message that the ink is having problems, which would be the reason for the lock-up after "please wait."
Please let me know if I can be of further assistance.
Posted on Nov 12, 2009
What is sc819 for ricoh aficio c4501
#3
teebee1234 teebee1234 is offline
Service Manager
1,000+ Posts
Ricoh Aficio 2035 SC819 Error Code
teebee1234's Avatar Join Date
Jul 2008
Location
Northville, MI
Posts
1,669
Rep Power
46
Yeah most likely the Hard Drive, just replace them with off the shelf ones. Could also be the dimms, controller, nvram or firmware. I would unplug the HDD first and try rebooting (clean and reseat the dimms while you're at it). If it boots up ok then replace the HDD. If still the error with the drive disconnected, swap out the memory dimms. Try reloading firmware before replacing any other parts.
Jan 24, 2018 | Ricoh Office Equipment & Supplies
Color coping
while printer is on, yank out power cord, wait 1 minute , and plug back in , printer will print now with no candy striping
Apr 03, 2014 | HP Officejet Pro 8600
Ricoh sc 672 error on new machine
  1. Go to this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
  2. Go to System Settings
  3. Go to 5875
  4. Check the setting of SP5875-001. If the setting is set to "1 (OFF)",change it to "0 (OFF)".
Try checking or changing the thermistors!
The metal contact spring on the thermistor broken causing all sorts of 'unrelated errors including 'Please Wait' sc 670 and sc 402...
Feb 28, 2012 | Ricoh Aficio 450 Copier
Hi, I have a "please wait" error showing an a Ricoh aficio 2027,i have changed the H.D.D but the prolem still shows,also i have fitted the faulty H.D.D in another machine of the same type and it works...
The "Please wait" error is almost always caused by a fault hard drive. Have you tried running a disk repair utility like Scandisk on one of the hard drives when it's attached to a computer? Maybe the "new" hard drive you put in was also bad. (It doesn't take many bad sectors or other problems for the copier to not be able to use it.)
If both of the hard drives are truly good, the problem could be the hard drive controller, which sits on the main controller board, and you'd have to replace that whole board.
Jun 09, 2010 | Ricoh Aficio 2027 Black and White Copier
Ricoh af2027 please wait with a wrench no code
Hi that normaly indicates the there is something wrong with the HDD. open the back of the machine and unplug the HDD. Swith the machine on. If it turns on the HDD is faulty. The machine will work without the HDD but you will not be able to use the doc server. To fix the HDD plug it in to a PC and initilize it. (right click my computer, manage, disk management, right click on drive, initilize. Put it back in the machine.) Should solve the problem.
Apr 27, 2010 | Ricoh Aficio 1035 Copier
Replaced the power supply/controller pca on a ricoh 2210l. prints fine, but copies come out black. adjust shading procedure yields copy with vertical black stripes and sometimes a faint negative image of...
If the tonner has gone old please take it out and shake if for atleast 2 to 3 minutes before putting it back and takng printouts. The issue would resolve but its a temporariy fix as you would require to change the tonner .
Let us know if you need further clarification.
Thanks
Dec 30, 2009 | Ricoh FAX2210L Plain Paper Laser
Clear a Ricoh Fax 2000G Memory
    1. If your documents have already been scanned into memory:
    2. touch the [Change/Stop TX File] key
    • check that the [Stop Transmission] key is selected
    • touch the file that you want to stop, then touch the [Stop Transmission] key in the confirmation dialog box
    • touch [Exit] to return to the Fax Mode display
    1. If your documents are being transmitted:
    2. press the red [Clear/Stop] key
Dec 22, 2008 | Ricoh 2050L Laser Fax
Ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Nov 05, 2008 | Ricoh Aficio 1035 Copier
Mode incorrectly switching to Handset
Hi Sue, Can you tell me if there is anything else conencted to your fax line? Most Ricoh products will display handset if the dialtone is not detected. It could be that something is using the line or is causing it to short. Another thing to check if the machine is an older 1515- if this occurs after you receive a fax and you are behind a PBX, there was a batch of modems in the Ricoh machines that had a problem with not disconnecting the line, resulting in the handset being displayed. Could be any number of items, normally I would start the troubleshhoting with line issues and go from there.. Brad
Aug 17, 2007 | Ricoh Aficio 1515F Plain Paper Laser Fax
46 people viewed this question
k24674
jasbo
jasbo
