Question about Cell Phones
How to reset my motorola rokr z6m because it just shows the motorola symbol when i turn it on and i wanna reset it to see if that fixes my problem
I wanna format my motorola rokr e6.. how can i
  1. Press the center button on the ROKR E6.
  2. Choose the "Setup" option from the list that appears.
  3. Tap the "Master Clear" option in the Setup list.
  4. Confirm that you want to erase the contents of your phone with the center button.
This will erase all of the phone's files, leaving you with a phone set to factory defaults.
Good Luck
Nov 29, 2010 | Motorola Mobility ROKR E6 Smartphone
White screen motorokr z6
try to update an new software to ur mob !!!!!!!!!!
Jul 25, 2009 | Motorola Mobility ROKR E1 Cellular Phone
When I turn on my Motorola Rocker Z6M it only shows a locked symbol
On the side of the phone there is a switch that locks the keypad. It must be in the down position when your phone is turned on, or it will stay locked. Hope this helps =)
Jul 08, 2009 | Motorola Mobility ROKR E2 Cellular Phone
Stuck on motorola logo
its an internal problem try taking out the battery for about 1 min or more and try it again. if doesnt work you will have to contact your phone service provider for a repalcement phone if under warranty or insurance.
Apr 22, 2009 | Cell Phones
Motorola ROKR z6m Media Player Not Functional
Okay, now this goes for if you can't see your pictures as well.
You need to make sure that there are not files for each song. Go onto the memory card and if there are folders for each song, move the songs onto the card 1 by 1 and delete the folders. It seems as though the folders are tricking the phone and making it shut down. The phone cannot process that many folders.
Once this is accomplished, you should be able to opperate like it should be.
Folders are created when you sink your media player to the phone, don't do this!
Move the songs over 1 by 1 to the music folder preinstalled on the memory card once formatted by the phone.
Dec 08, 2008 | Motorola Mobility ROKR E6 Smartphone
Moto rokr z6m
the only way to fix it is:
plug it to the charger
leave it one hour
then remove the battery and put it on after 5 seconds
and turn it on
repeat as necessary
it will take a while but thats the only way i fixed mines
Oct 04, 2008 | Motorola Mobility ROKR E1 Cellular Phone
Motorola ROKR Z6m, backlight staying lit, question re: charging
The Z6m is defaulted for the backlight to stay in dim mode. In order to change this setting, go to initial setup, display timeout-1 min and it will then turn off.
Hope this helps!
Mar 11, 2008 | Cell Phones
Help
u should load music to the music folder on the card ... same thing had happened to me in the diff motorolla model ...
Dec 23, 2007 | Motorola Mobility ROKR E1 Cellular Phone
Cell Phones Logo
1,035 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
