Question about Price Pfister R89-7PC0 Chrome Portland Single Handle Pressure Balanced Show
Water leaks out of shower head during tub use. valve was installed properly
  • 43,501 Answers
The pipe to the tub spout is either restricted or the valve was placedd too high causing some of the water to come up and out of the shower head instead of it all flowing out of the spout.
Posted on Nov 12, 2009
Have changed all washers and reseated taps in shower but shower head still leaks
hi mark.
this is all i could find on the internet,if this is no good to you go to the link at the bottom and see if it helps you out.
First, feel the water leaking from the tub spout or shower head. If it's warm, you know that the leak is coming from the hot-water valve. If the water has been dripping for a while and it is cold, the leak is probably coming from the cold-water valve. 1Start by removing the faucet handle.22 Nov 2016
How to Repair a Leaky Shower Faucet Valve - HomeTips
shower head leaks Google Search
Nov 18, 2017 | Home
My husband in stalled in shower vavle body. When bathtub is filling, water comes out shower head any ideas.
It's possible you installed the valve upside down, all values should be labeled in some way marking either hot and cold or it will say the word up where the riser tube port for the shower head is. If that's not the case remove the tub spout and check for any obstruction sometimes during tile or constructing debris can get into the pipe for your tub spout. Lastly the diverter on the tub spout could be bad. Try a new tub spout
Mar 05, 2016 | American Standard Home
Water leak thru valve when turn to shower
a lot of shower diverters do this..you may need a bigger seal on the diverter..if you can remove the spout assembly from the tub(with the diverter valve in it) and take it all to the hardware store.. see if they have a different seal/diverter that has a snugger fit but still falls to drain the shower head line out..that will slow that leakage..the spout is on a pipe and unscrews counter clockwise(normally)unless its a single valve unit..with the wide ring around the back..then that calls for a plumber..
Jan 21, 2014 | Moen & Bayhill& Single Handle Tub & Shower...
Moen Shower Valve Model L82839 installed: Water comes out of shower head when running bath. Thanks.
Only two possibilities here the diverter tub spout is not open all the way to let water to the tub only or the shower valve is installed up-side-down.
http://www.moen.com/shared/pdf/l82691pt.pdf
Mar 06, 2011 | Moen & Posi-Temp Single Handle Shower Or...
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Hand held shower head leaking where connected to bracket
If it leaks continuously during use, verify that a rubber washer was used in that connection and that the connection is tight.
If it only leaks after the water is shut-off, there is a vacuum breaker installed there, which prevents water from siphoning back into your water system. It is normal for water to drain at this connection when the water is shut off.
Jan 25, 2010 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Price Pfister R89-7PC0 Chrome Portland Single Handle Pressure Balanced Show Logo
198 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Donni Steen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
