Question about Gateway FPD2275W LCD Monitor
Samsung monitor blacks out --
I have a 3 year old Samsung monitor that worked fine until recently. Now when you open a full screen 3D application, the screen goes black and the monitor appears to shut down although technically I don't think its off. The same situation occurs if you shutdown the monitor and try to restart it again. It occurs with DVI and VGA connections and it occurs regardless of the source computer or applicable video card. If the monitor rests for 15 minutes and then restarted, it will function again. Sounds like some electrical component no longer handling surge loads.
I'd like to at least have a repair shop see if it can be repaired and provide an estimate . I've called a couple of the shops on your link but they say that don't typically handle and provide repairs and estimates for monitors - even though I'd be willing to pay a reseasonable charge to look and it and advise whats would be needed ---suggestions
    Champion:
  • 220 Answers
The problem should be dry joints in powersupply section and horizontal output section.Resolder all components mounted on heatsinks HOT Vertical O/P Ic etc.
Samir
Posted on Mar 07, 2008
Monitor went black
I have same problem. only 13month worked.
Jul 26, 2010 | Samsung Home Security
I HAVE A SAMSUNG 2253 22' LCD MONITOR,POWER LIGHT FLASHES,AND SCREEN STAYS BLACK ,IT TRYS TO LIGHT UP ,BUT STAYS BLACK,MY OLD TINY 15' LCD WORKS FINE ON THE SAME COMPUTER,MY 22 USED TO WORK FINE??????
A flashing power light like that indicated a blown power supply. Your monitor should be under warranty with Samsung. Check the mfg date on the back sticker, if it is less than 3 years then contact Samsung. If it is out of warranty then contact us at tech@ccl-la.com and we can get you the info you need to do the repair yourself.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Computers & Internet
Trouble with Samsung 2233RZ
The same to me
I think the monitor is broken
Sep 06, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
Monitor cold start issue only as #2 monitor
The start up problem is common and will only get worse. Call Samsung as these monitors have a 3-year warranty. No receipt? They will accept your word regarding your purchase. I have two that failed exactly the same way. I called 1-800-SAMSUNG and they gave me the choice of an exchange pair sent directly to my house (requiring a temporary credit card deposit) or by having the exchange pair sent to the UPS store where I would swap out my bad units. No receipt. They merely asked me when I purchased it so they could have it for their records. Manufacture dates such as your (March '06) and a purchase of September '06 are not far fetched at all. .
May 19, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Black screen blinking green light
You have a bad backlight fluorescent bulb.
Dec 28, 2008 | KDS 17S 17" Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
I have 2 samsung 710N LCD monitors that are exhibiting the same symptoms. When they are powered on, they display fine for about 10 seconds, and then go completely black. If you turn them on and off again,...
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Mar 19, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Gateway FPD2275W LCD Monitor Logo
281 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
