Question about Photography
I have 2 Rollei Magic I cameras with broken automatic shutter release. Can you fix and how much? How long? Basque478
4 Suggested Answers
poolseman
  • 206 Answers
SOURCE: MInolta x-300s film camera - shutter will not work
Remove bottom cover ( 4 screws ) and find small shutter release capacitor ( 6 v 220 microF ) and replace it. These older capacitors start leaking after 8 years and have to be replaced. Make sure you get the polarity and specs right when you are putting a new one in.
Posted on Sep 03, 2007
poolseman
  • 206 Answers
SOURCE: my X700's shutter isn't working when i press the shutter release
Remove bottom cover and locate the 6v 220 microF capacitor and replace . The capacitors that go into these models start leaking after 10 years.
  • 619 Answers
SOURCE: Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Posted on Feb 28, 2008
Rolleiflex sl35 mirror stuck in the open position and shutter won't release to send the mirror back down.
Try this: Give the shutter button a few quick, hard pokes with your finger. Don't be shy, you've got to give it a few good jabs. This can get the mirror unstuck. It's helped me before...
Mar 10, 2014 | Rollei Genuine Slr Sl35 Etc Front Body Cap
Shutter broken
can you please give the make and the model no. so that i can find the parts for it..
Waiting for your reply
May 01, 2008 | Rollei Fototechnic Giro 70 35mm Point and...
Connection to Rolleiflex SL2000F SLR
I checked out a SL2000F that had good pictures on eBay. I see a standard hot shoe on the side of the camera. That being said, neither a standard shoe connection nor a pc outlet will give you TTL on the Metz. TTL is Transistor to transistor logic (or for camera store people, through the lens) A sensor that reads the light from the actual plane of the shutter is required to allow the Metz to give TTL operation. It will work on the Auto setting, but the Rollei does not have the sensor as described.
Feb 18, 2008 | Rollei SCA 356 Flash
I am in China,how can I buy this shutter?
Don't worry, you can go to shuttermaster.co.uk site where you can easily find the better and cheapest shutters for your home.
Dec 03, 2013 | Rollei Electronic Shutter Size "0" for...
I cannot retract the lens back to my Rollei 35 se
Your question seems to be mis-categorized under slide projectors, if you are asking about Rollei 35 SE camera, the lens will only retract if you cock the shutter with the wind lever, then press the button next to the shutter release and rotate the lens a few degrees.
Nov 13, 2013 | Rollei 66 Dual Slide Projector
Interlocks on Rollei 35
The camera would have to be torn down a repaired. Its worth is about $25 to $50 on Ebay at this time
Jan 14, 2010 | Photography
Rollei 35 LED: lens barrel jammed out; shutter speeds all the same - the fastest.
How long have you been having this problem? Did you drop or hit the lens while it was out? Once I have more information I will be able to assist you further.
Thanks,
Lee
Sep 14, 2008 | Rollei Cameras
Shutter Broken
hi,
ok,Since your camera is same as the pic shown then it must be giro 70.Anyways If you have a bill or a warranty card you can have a look at it for the model no.
May 02, 2008 | Rollei Fototechnic Giro 70 35mm Point and...
Shutter release
Feb 19, 2008 | Photography
Shuter release button stuck
Caused by build up of dirt inside shutter release button :drip small amount of cleaning solvent like methilated spirits , isopropanol or benzine between the button and external wall using tweezers and then lift the button up and down by inserting tweezers into the inner cable release  thread .
If this does not work you will need to remove the front cover and clean more fully the release mechanism on the inside of the fron cover. 4 retaining screws are under the leather covering in the front ( 2 on top and two on the bottom )
Oct 11, 2007 | Rolleiflex 4.0 FW Medium Format Camera
Photography Logo
234 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
