Question about Nikon D2Xs (Body Only) Digital Camera
D2xs has no menu options, just a menu option with the wrench icon, firmware version says 7.30 and 7.31 cant reset anything on the camera need to know if the problem can b fixed
4 Suggested Answers
  • 18 Answers
SOURCE: Canon Digital Rebel bracketing
Do you have the dial set to either P, Tv, Av, M or A-DEP? It will only work in those modes, and will probably only be in the camera icon menu when the camera is set to one of those modes.
Hope that helps.
Posted on Feb 24, 2008
reid_andrew
SOURCE: how do you turn off beep on Nikon P510
Only 3 options show but you can page down for more options
Posted on Oct 18, 2012
  • 102366 Answers
SOURCE: D3 will not show option to do firmware upgrade from 1.0 to 2.02
Copy just the AD3_0202.BIN file to the top level of a formatted CF card. Insert the card and select Firmware from the Setup menu.
Repeat the process using just the BD3_0202.BIN file.
Full instructions are here.
Posted on Oct 23, 2012
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
Setting my canon powershot s5is to the english language
The cameras are not meant to have multiple languages. You accidentally received a Japanese version of the camera. Call of the manufacturer and they should send you an English version. Let me know if you need anything else and I would be glad to help
Jun 26, 2008 | Canon PowerShot S5 IS Digital Camera
Reset language
Press the MENU button, select the wrench icon, then select the seventeenth item on the submenu. I know it's a pain when you can't read the language it's currently in. All camera makers seem to have trouble understanding that the main reason someone wants to change the language is that the someone can't read the menu.
If you're not sure you've got the right item, you can always go into each submenu in turn. If there's an option labeled "English," select it. If not, just back out without changing anything.
Dec 18, 2013 | Cameras
RESET ALL Button
I'm convinced you already did read the user manual. There are three things you can reset:
1. User settings. In menu mode P, you can undo all the settings you made. Page 69.
2. Reset all settings. Page 151 Menu settings, chose the wrench symbol and chose reset all. All settings will be restored to factory settings.
3. Reset file numbering. Page 154 Menu settings, chose the wrench symbol and chose reset file numbering.
In the same menu is also the view firmware version. Yours should read Coolpix P90 Ver.X.X .
The latest update of firmware for the P90 is 1.1 Great chance your camera came with that revision already. If you registered your camera with Nikon, they will inform you when a new firmware is released.
Really, there is nothing more you can reset on the camera.
So if something is wrong, it can't be helped with the reset you have in mind, because that reset does not exist.
If you want the firmware 1.1, goto Nikon USA and support. Everything you want is there.
Nov 29, 2013 | Nikon COOLPIX P90 Digital Camera
How do you turn off beep on Nikon P510
Oct 12, 2012 | Nikon COOLPIX P5100 Digital Camera
How do i Reset my Dsc-T5 menu language
Press the MENU button. Select the toolbox icon. Select the toolbox-1 icon. Select the "A" icon.
Sep 30, 2012 | Sony Cyber-Shot DSC-T5 Digital Camera
How do you change the language on a nikon coolpix L1
Press the Menu button. Select Setup (the wrench icon). Select Language (the waving flag icon. In that menu, each language is labeled in that language, so you should see "English" as one of the options. Select that, and everything should be back in English.
Apr 15, 2012 | Nikon Coolpix S550 10 Megapixel Digital...
All main menu icons dissapeared while installing an app from cydi
I would do a full reset on the iphone which you can get to by going to the settings and scroll to the bottom and it should give you a reset option this will delete everything but assuming you make a backup whilst in itunes you should be able to re synch it as far as contacts and anything else you want from your itunes afterwards.
Jun 28, 2009 | Apple iPhone Smartphone
Camera in japanese language i want in english LUMIX DMC TZ5
Select menu
Select spanner(wrench) for setup menu.
Scroll down through the menu, there are five pages of menu items on my camera! it moves to a new page when you move off the bottom.
The language option is the penultimate item - it has an icon of a head with a speech bubble.
Dec 02, 2008 | Panasonic Lumix DMC-TZ5A Digital Camera
Nikon D2Xs (Body Only) Digital Camera Logo
66 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
