-   Coffee is not staying warm or hot after it has brewed. Any help would be greatly appreciated.-   srodgers1116
Mar 12, 2008
-   I have a West Bend 100 cup Coffee urn model # 33600 and the coffee is not getting hot. The red light is coming on in about 10-15 minutes after turning the unit on. I have cleaned the heating element hole where the stem fits in with no avail. I have checked the stem seat and it fits good in hole. I'm thinking the heating element is kicking out early. Is this element available? or what else could it be?-   Guest
Feb 25, 2008
-   Our coffee isn't hot enough either.-   Guest
trixie36 how many time i saw that coffee machine ruined because of calcium billdup use a descaler product normally 1 part cleaner 1 part water run the machine stop for a while stop let the product do it job emty everything and dont foget to rinse it very good that stuff is very corrosif cheers
You are useing a coffemaschine with Nespresso capsul system. Nespresso does not allow the Temperature (out of the mashine) above 89°C . This mashines have normaly 86°C +/- 3°C. Above 89°C the coffee will burn and the tast is ruined.
Solution:
Heat up you cup with hot steam and then make you coffee....
Mr. Cool
Was this helpful?
Yes
No
Popular Solutions for Miele CVA2660 Stainless Steel
having descaled the miele built in coffee machine cva 2660 error f74 came up and it will no longer...
(More)
having descaled the miele built in coffee machine cva 2660 error f74 came up and it will no longer foam the milk for coffee or hot chocolate. what could be the problem ?
