Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Num lock is default on, even when I don't have a keyboard attached. Every time I boot up, I have to turn off num lock just to be able to type my password and log on to my PC. How do I fix this?
  • Chuck Kao Nov 13, 2009
    NumLock does affect your login when you're on a laptop without an external keyboard attached since you may want to enter a U when you're actually entering a 4.
    Thanks for the solution but it didn't help. There is no keyboard setting in the BIOS. I looked and looked.
    President:
  • 2,049 Answers
NumLock should not affect your login at all. It still allows you to type in alpha-numeric.
If you want to switch off auto-numlock, go into your BIOS as your computer boots up and change the setting which triggers it.
Posted on Nov 12, 2009
  • Bill Schilz
    Bill Schilz Nov 13, 2009
    You've somehow missed it in BIOS... look for POST behavior or similar.
    There is definitely a switch for numlocks within BIOS
Logitech Wave K350 won't boot with num lock on
Have you changed or updated anything else on your system? Added any other Bluetooth devices? I have the same KB, always boots with Num lock on. It worked with both Vista 64 and now Win 7. Maybe the driver and the specific USB port combination is not working. Try plugging the BT antenna into another USB port.
Mar 04, 2014 | Logitech Computers & Internet
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
Dell Keyboar Problem -
This likely is one of two issues. A BIOS setting, and can be changed in the BIOS setup utility accessible at startup.
Or ...
If you are sure you have no computer virus or a hardware conflict than you can modify this setting by editing the registry on the computer. Normally, the computer applies the user settings when the user logs on, but it uses the default user profile when it is first turned on, before the user has logged on. To turn this functionality off, the default user settings must be modified. The Keyboard entry contains user preferences as defined by choosing the Keyboard icon in Control Panel. Entries are found under this registry path:
HKEY_USERS\.DEFAULT\Control Panel\Keyboard
InitialKeyboardIndicators REG_SZ Number set it default to 0.
If not:
* Run the Registry Editor (REGEDIT.EXE).
* Open HKEY_CURRENT_USER\Control Panel\Keyboard (If the Keyboard key isn't there, add it.)
* Double-click the InitialKeyboardIndicators value on the right. (If it's not there, select New from the Edit menu, then String Value, and type InitialKeyboardIndicators for the name of the new value.)
* Change the value to any of the following:
0 - all indicators off
1 - Caps Lock on
2 - Num Lock on
4 - Scroll Lock on
Or, combine them by adding the corresponding values:
3 - Caps Lock and Num Lock on
5 - Caps Lock and Scroll Lock on
6 - Num Lock and Scroll Lock on
7 - Caps Lock, Num Lock, and Scroll Lock on
* Close the Registry Editor when you're done.
All the change should take effect when next time you start Windows.
Aug 28, 2009 | Dell 0Y3740 Keyboard
BLINKING Num Lock, Caps Lock & Scroll Lock
Put the RAM back in or check the RAM in securely
Apr 13, 2009 | E-Machines AAFQ50400000K0 Keyboard
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
When i turn my computer on i always have to turn on the num lock. i think my num lock should stay on even though i restart my computer.
How to get Registry cleaner.
Windows XP
Click START>RUN
Type regedit
Click ok
Windows Vista
Click Start and type regedit on your keyboard HIT ENTER.
Than:
you can turn on num lock by changing "HKEY_CURRENT_USER, Control Panel, Keyboard, InitialKeyboardIndicators" to "2"
OR if that single registry entry doesn't solve your problem than go for this.
HKEY_USERS\.DEFAULT\Control Panel\Keyboard\InitialKeyBoardIndicators
Dec 28, 2008 | Logitech Cordless Desktop MX3200 Laser...
Keyboard
Not a big problem...
You probably have an external keyboard attached to the laptop at some point yes?
Easiest way to fix is attach an external keyboard and disable # lock.
Or on your keyboard.. use the FN key and hold it while you press the key on your laptop that has NUM or # on it. Look at the lights on the laptop to see if NUM LOCK is enable.
best wishes.
Oct 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Where is num lock button on Gateway MA7?
Fn+Scroll will toggle the Num Lock
The ison on the keyboard is a purple Lock with the number 1 inside.
Jun 07, 2008 | Gateway MX6920 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
600 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
