I have a xerox 5016 copier ,
I am getting u4 error can you tell me how to correct it, really old model
  • 239 Answers
On this model, yes it can be the fuser thermistor, fuser relay, driver board, main board, especially the fuser fan turning very slow not up to speed.
Any of these combination can be a problem.
Also, there can be bad fuser rod connections that can cause this type of problems, and can only be repaired by a Xerox Service Representative.
Posted on Oct 16, 2009
  • 53 Answers
All U4 codes on Xerox machines relate to the "fuser".( That's the hot bit on the way out) You will find the rollers fail to warm up, or reach correct temperature .
Most often the heater rod inside has burned out, or sometimes the overheat thermostat goes open circuit.Both problems will require the fuser unit pulling out of the machine and a test meter to check continuity of the components
Posted on Jan 08, 2008
How can fix error u4 code in xerox photocopier machine
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
Feb 19, 2018 | Xerox Office Equipment & Supplies
Error U4-1000 (Xerox CopyCentre C116 copier)
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
Apr 12, 2011 | Xerox CopyCentre C118 Copier
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
I have Xerox 5016 model Photocopier , I am getting Error U4 ,some technican from Xerox advised that it can be solved by pressing some button ..? If anyone can support would be a great help.
Enter into the diagnostic mode.Press 50 then green button,press 20 then green button,press 00 then green button.Switch off the machine & Switch On.
Jan 15, 2011 | Office Equipment & Supplies
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
On this model sometimes the plugs on the connectors go bad.
They arc and will not connect good. Sometimes the ends have to be clipped and new pins male and female have to be crimped back on, replacing them on the machine part wiring connectors and fuser rod ends. this fuser kit is a part that is availiable at xerox.
A bad thermistor can cause this type of problem. If the machine overheats, the fuser triac pack can cause over heat problems as well.
On overheats the fuser fuse needs to be replaced. Do not replace with nothing else but a Xerox fuse, this is a safety device. Very important.
Otherwise place a service call to have this area repaired by xerox.
Oct 23, 2008 | Xerox DocuColor 12 Printer
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
829 people viewed this question
