Question about Dacor Preference PGR30 Gas Kitchen Range
My Dacor PGR-30 oven won't heat. It stays on 135 degrees. There are no codes set.
Called Dacor with same problem. They said the high temp switch needed to be reset but wouldn't tell me how to do it.
Looked at another site and found out how. On double oven remove grill that latch sticks out of. There should be 6 screws. On left side is a switch with a red button that faces inward. Press this button until it clicks. Test oven by turning on to see if this fixes problem. It did for me.
Rescrew grill back on being careful that the latch continues to line up with the door.
Posted on Oct 05, 2011
Pgr 30 oven takes a long time to heat up
Hot surface Ignitor is bad most likely. Normal wear and tear. You can check it by looking at it, it should be black. If it's white, it's no good.
Dacor oven repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Dacor Preference PGR30SS Gas Kitchen Range
Power was turned off. I reset the clock to proper
We have the exact same problem. It doesn't heat to above 135. Help!!
Jan 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
Dacor PGR 30 oven does not heat
I have had the same miserable experience - replacing the brain, touchpad, expensive parts - for this supposedly high-end appliance.
Have you checked the ignitor bar? See a good explanation of that at http://www.ignitors.com/oven-ignitors/
and also http://www.theignitorstore.com/product/frigidaire_oven_range_igniter_5303935066/range_oven_igniters
Nov 23, 2009 | Dacor Preference PGR30 Gas Kitchen Range
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Dacor rsd305
yes, you need to open the panel (in the center of the front of the oven when you open the door on the top) and press the reset button, there is a site that gives step by step instructions, but i can no longer find it
Jul 22, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
REALLY long to preheat ...
I had the same problem; replace ignitor
Jan 16, 2008 | Dacor Preference PGR30SS Gas Kitchen Range
Oven not heating
i have had this problem twice. once was the heating element actually had shorted out because the little ceramic holders had broken, this necessitated getting new element. can be checked out with an ohmmeter by yourself or by taking element into appliance repair place. the other time, it was that the manual reset switch had tripped after a self-clean cycle. actually at the moment, that has happened again- design flaw perhaps in the RSD30 range?
so anyone who can tell a reasonable competent refrigeration/HVAC technician where the manual reset switch is would be appreciated.
Oct 28, 2007 | Dacor ECS127 Epicure Electric Single Oven
Dacor Preference PGR30 Gas Kitchen Range Logo
709 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
240cpa
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
