Question about D-Link (DI-711) Router
Dlink router wont connect to enternet
After i correctly install the dlink router it wont connect the enternet to my desktop by ethernet or to my laptop by wireless
  • 2,260 Answers
So that means you are not able to go online using the router.
If you connect the computer directly to the modem, does it work ?
If that works then the modem is working properly.
You can try to reset the router for 30 seconds , then unplug the power to the router and plug it back in. Wait for 1 minutes and then try to set up the router manually.
Click Here for more info about how to set up the router manually
Posted on Nov 12, 2009
Hp a345w desktop pc dcs server not found conflict
what OS, we can NOT GUESS your operating system.
so where are you , home or star bucks.?
what is your connection, wifi, ethernet, or others?
a desktop pc can have vast ways to get internet.
1: modem dial up (i bet not this, nobody uses this now, 99.9)
2: cable modem, sat modem, fiber modem to ISP
3: USB wifi dongle, on PC and to local router.
4: PCI card wifi. , to router.
5: ethernet wired to router or modem direct. a cable wire. CAT5/6
one can even have direct wired ethernet to the cable modem
or you might have wired to wifi router (2 ways to connect there)
NO OS stated
no connections stated.
my guess is DCS, means DHCP not found, or DNS not found.
lots of causes, but I will not attempt to answer for all 6 ways.
sorry
May 30, 2017 | HP Computers & Internet
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
My new roku 2 will not connect to internet my wireless router is a dlink dir 615 and I know I am using the correct password
Upgrade to an ethernet cable connection between the router and the Roku. There is a slot on the side of the Roku box for it. This should enable you to enter the password- and give you a more stable streaming experience
Mar 08, 2014 | D-Link DIR-615 Wireless Router
Do i need to install any software on my computer to activate my dlink router.
There is no need to install any software in your computer in order to activate your DLink router. Just make all the connections (included the ethernet connection from the router to your pc, it's better to make the settings using ethernet than using WiFi), open your browser (Internet Explorer, Mozilla e.t.c.) and go at the router's page.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 30, 2010 | D-Link (DI-711) Router
Wbr-2310 dlink router wired connection issue
connect your computer to the router by an ethernet cable. Open Internet explorer or FIREFOX. Type the roiuter's default IP-address (if not known: its either 192.168.0.1 or 192.168.1.1 or 192.168.0.0 or 192.168.1.0... keep trying until you're answered and asked for the password to enter the router (either attached on the router, in the manual or try: user: admin password: admin or password: password. Whgen you're in you'll find many checkboxes you could fill oput or notr; Easyway: give your net a name (SSID), then choose the network access security (set it to wpa-psk), choose a password and enable DHCP (then the router does the rest). Disconnect, look if the computer sjhows reception of your netwoirk by displaying its name. then connect. You will be asked for the password you chose. Done.
Jun 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink wireless windows vista
Connect an Ethernet cable to one of the 'LAN' ports on the router and to the network-port on your computer.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER.
You should get output like:
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 124.268.336.448
Default Gateway . . . . . . . . . : 123.456.789.0
Start Internet Explorer.
Type: http://123.456.789.0
to connect to the web-server "inside" the router.
Run the "wireless network setup wizard" to configure the router
with an SSID and a password.
Save and reboot the router.
Disconnect the Ethernet cable.
Your computer should report "Wireless Networks are available".
Choose your network, and enter the password for the network.
Nov 18, 2009 | D-Link DIR-615 Wireless Router
Hi. I just configured a DLink DIR-300 wireless router on my laptop. During the installation, it required me to keep the ethernet cable connected between the router & the laptop. I finished the...
First you have to check on your laptop that your wi fi network drivers are installed correctly.
Also check it is enabled.
Also check wi fi switch on laptop is turn on.
Check its ip addreses and subnet amsk and gateway is proeprly.
Aug 19, 2009 | D-Link DIR-300 Wireless Router
Router and New Print Server Not Talking?
what hardware version and firmware is on router.you might need to update firmware depending on what firmware is on now.
Aug 15, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
CISCO 2800 router interface stop responding
What kind of cable do you have connected from the DLINK to the Router? Is it an ethernet cable 3,5e,6?
Sep 13, 2007 | 3Com OfficeConnect (3CRWE454G75)...
D-Link (DI-711) Router Logo
123 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
