Need to remove the rubber seal from my lg front load wahser
Need to remove the moldy rubber seal from myLG front load washer ane replace in with a new one
  • 155 Answers
Why replace seal just clean it much easier there are some really good cleaners on the market but if you realy want to replace remove wire band around seal you will see this around the outer diameter with a tension spring attached pry of carefully lift the top and do the same at other end make sure to turn of power take very good note so you will know how to put back together
Posted on Nov 12, 2009
I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
Daniel
Aug 30, 2010 | LG WM-2077C Front Load Washer
What does de mean on the display of the washing machine? Yesterday I ran a tub clean because my clothes have been smelling moldy. I have cleaned the rubber seal & leave the door open. Please help??
de means your door isn't closed completely.
The moldy smell is really common with this machine, and maybe all of them, but I have the LG TROMM and was ready to throw away all of my towels. Here's a solution I found that helped alot. First, Clorox makes a solution just for front-end loading machines. You run it through on a cycle with no clothes, that helps to clean it out.
I ran my towels through on the cotton/towel cycle on HOT, with nothing more than white vinegar filling the detergent dispenser. After that, I then ran them through again with just a bit of soap and fabric softener. They came out soft and smelling like new.
I read recently that we all use WAY too much soap in both our washers and dishwashers, even though that's what's recommended in the directions. Excess soap in clothes that doesn't get rinsed out will begin to smell moldy. So I now use about 1/4 of what the directions call for, and they come out fine. I have found, however, that I need to repeat the vinegar cycle once every few months. I think the problem is inherent in that model machine.
And that rubber seal? Disgusting! I clean it out regularly, but when it's full of water after every load of clothes, what do they think is going to happen??? You'll find that Clorox cycle will clean the seal pretty well, though. Good luck!
Apr 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How do you remove the rubber seal in a front load
There is a spring band on thr fromt lip of the seal and the seal closest to the tub.To remive use a flat slim tool to lightly pry up on the band and it till pop off.Same with the inner band.
Oct 01, 2009 | LG Washing Machines
Circular grey rubber part ..
firstly u have to take the wire off it with a screwdriver unscrew it take it off then watch how the old on pulls off as there is a lip all around this rubber and it as to bed into the metal drum just see how the old one comes off once you have put the new one on put the wire back around it or it could be a metal strat wich tightens up with a screwdriver,rgds,paul
Jul 07, 2009 | LG WM-1832C Front Load Washer
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
