Question about Maytag Dryers
I need help replacing maytag dryer belt model no.sde305dayw . I am having a problem getting around the pulley maytag dryer
  • 304 Answers
The Link below will show you the configuration for all dryers. Choose the one that looks most like yours keeping in mind that some dryers are made under several different names: Good Luck
Belt Configuration
Posted on Nov 12, 2009
I have a Maytag SE-1000 stacking washer dryer setup. I am trying to replace a broken dryer belt, and have the disassembly done, and the replacement belt in place. My problem is trying to understand how the...
Most dryers are tension idler pulley directed but must first go around the grooved pulley on the motor shaft. make sure the idler goes on the smooth side of the belt and the grooved side of the belt is in the grooves on the motor shaft.
Oct 13, 2013 | Maytag Dryers
Need SDE305DAYW dryer belt routing diagram. Please help
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Scroll down and you'll find the maytage diagram. There are many, but it's about half way down.
Good luck, it might help to have a buddy help for an extra set of hands.
Mike
Aug 04, 2011 | Maytag PYE2300AY Electric Dryer
In my Maytag dryer model SDE305DAYW the heating element works; however, the tumble drum stopped moving. What's wrong?
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Dec 15, 2010 | Maytag HYE3657A Electric Dryer
How do I replace the dryer belt on a maytag dryer model #pye2300ayw. How do you connect to the pulley and get the belt around the drum?
lift the hood by pushing in clip on either side. remove two screw at top inside to remove front. unplug first. thats as far as we go there. remove belt out of dryer. take new belt and put on drum groove side down, get it uniform around drum. putting belt on pulley might be easier to do from behind for you. two screws to remove small access panel.take belt under pulley and over and around motor pulley. turn drum slowiy to make sure belt is not twisted. this belt can only go on a couple ways and one is obviously wrong. good luck.
Jan 30, 2010 | Maytag Dryers
Maytag dryer 2004 model # sde305dayw trying to replace the belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Oct 26, 2009 | Maytag Dryers
Model: maytag LDE9606ACE reinstall belt
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram E for a Maytag dryer. If you have questions, please let me know. I hope this helps you.
Sep 25, 2009 | Dryers
Drum belt tension
I found a dryer manual on the web that showed how the drum belt wrapped around the pulleys.
Problem solved.
May 11, 2009 | Maytag Dryers
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Dryers Logo
461 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
