Question about Canon PIXMA iP4000 InkJet Photo Printer
Printer does not print magenta and cyan. Change
Printer does not print magenta and cyan. Change of cartdridges does not help !! I have cleaned the printhead several times with isopropyl alcohol blow through. No help. Horst Pokorra
    President:
  • 787 Answers
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Posted on Nov 12, 2009
My printer prints in green not other colours
Most printers have 4 color inks: Black, magenta, cyan, yellow.
If your magenta ink isn't printing, then your prints will have a green cast.
If your printer has a "nozzle test", I suggest doing that. If it has a "head clean" function, that may help.
Replacing the magenta ink cart may be all that's needed.
Jun 20, 2015 | Office Equipment & Supplies
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
I wish to clean the colour printing. I've cleaned
hello mvn 500 your printer is a inkjet say yes please remove the your colour catridge or laser printer please change the magenta ink only because laser was a 4 colour option cyan, magenta, yellow and black
Jul 02, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Red is not printing properly.
That is caused by a defective print head.
Mar 17, 2009 | Xerox Phaser 8500/DN Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Hp 4600 no cyan printing
Firstoff, if you have tray 1 set to "any size" & "any type" they had problems with it going into calibration to frequently. If you upgrade the firmware this will take care of that. As for no Cyan, check the scanner interlock to insure it is opening the scanner cover. You could also go into diagnostics and disable cartridge check and swap the cartridges around, ie. cyan & magenta, run the print quality pages and see if the problem follows the cartridge. It could also be HV power supply.
Jun 18, 2008 | HP LaserJet 4600dn Color Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
540 people viewed this question
old marine
old marine
