Question about Canon PIXMA MP780 All-In-One InkJet Printer
RUBISH PRINTING ,NOT GIVING SELF TEST - Canon PIXMA MP780 All-In-One InkJet Printer
    Guru:
  • 480 Answers
Ok all you need to reset the printer.
You switch off the printer.
When you are swithcing on the printer hold the power-button for 30 seconds
that`s all, it will print the self test page...
Posted on Nov 12, 2009
  • leonard zamkoff Aug 14, 2011
    That doesn't work on my MP780.
Excel file is sent but wont print
Try printing a self test from the printer. If that works try a self test from the printer driver. That should help narrow it down to a PC, printer, or software issue.
Jul 22, 2015 | Datamax E-CLASS DMX-E-4204 Label Printer
Self test is printing but system print is not printing
Dear there is no control panel switch on printer how you got self test?. it might be engine test.. Was the printer recognised by the system?.. if no replace "POD" cable then check..
if yes check for drivers,.Test page is coming from system but print is not coming, do virus check for files, create fresh word page then try..
Sep 18, 2011 | HP LaserJet 1000 Printer
My printer is giving proper self test but not printing data from pc
Check whether the drivers are installed properly in device manager.
Sep 29, 2010 | Office Equipment & Supplies
Lexmark x5495 all in one.paper does not come out when printing
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridge. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have HP deskjet F4288 ,print is not comming.
Try printing a self-test page... to do that please follow below instructions...
Printing a self-test page Follow these steps to print a self-test page from the control panel. Make sure paper is loaded correctly in the product before beginning the procedure.
  1. Press and hold the power button (c01346625.gif ), and then press the cancel button (c01361518.jpg ).
  2. Release both buttons. The self-test page prints.
Thank you.....
Jan 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printing Problem in Windows XP
Does it seem to print the Windows test page faster than the self test print? If so it is probably printing the self test in a higher resolution than the Win test print (Win test prints are usually printed in low res)
Try printing a simple graphic or document from a piece of software. First in DRAFT mode and then in the HIGHEST Quality setting. See if you notice the "jerky" sensation in the DRAFT mode.
It could be normal for you printer.
Oct 14, 2008 | Epson TM T88 Thermal Printer
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Slow Printing
Hi, The slow printing issue can occure even if the cartridges are out or low in ink try to check the print function by the stand alone unit by printing a self test page Here are the steps to print a self test page: On the front panel of the product, press Menu (or Setup) . Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK . Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK . If the self test page takes less time to print and if all the color blocks and black block print fine the ink level are fine. if the time for self test is also more try to clean the cartridge contacts and replace the cartridges if needed this will fix the issue. If the printer works fine as stand alone self test and copy try to performe the steps in the below webpage: ========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=us&dlc=en&product=2512010&rule=10185&lang=en ========== If the issue is still un fixed try to set the print directly settings in the printer properties Click on start >> control panel >> printer and faxes >> there look for the HP printer icon with the check mark and right click on it and select properties and then click on advance tab and under it select the print directly to printer and click on apply and ok to save the settings. Once done try to print and check with the issue. Hope this will fix the issue. Regards, Barret.
Sep 03, 2007 | HP PSC 2175 All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
199 people viewed this question
old marine
old marine
