Question about Whirlpool Duet GHW9150P Front Load Washer
F6 message on my duet front load washer - Whirlpool Duet GHW9150P Front Load Washer
  • 26 Answers
Drive motor tachometer error. is unit agitating/spinning?
Posted on Nov 12, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
jsrock516
  • 5911 Answers
SOURCE: whirlpool duet front load
The "F06" error is a Motor Speed problem. You may have a problem with either your drive motor, motor control unit or main computer board (known as a CCU). The following link explains how to check and determine what may be causing your problem:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
If you have any questions, or require additional assistance, please let me know. I hope this helps.
PS Check for the obvious first. Make sure the drive belt is still attached and not broken before getting too deep into troubleshooting everything else. NOTE: More commonly, this is an indication of a motor control unit failure.
Posted on Aug 11, 2008
  • 99 Answers
SOURCE: Grinding duet ghw9150pw4 front load washer
This is joyce
I just had to have my barrons replaced in my washer on the spin cycle it sounded like plane taking off. I dont know about yours but mine was loud, you probl. have the same problem. get a technician to come and check it out, all these machine's are hard to work on so let professional take care of it. if you need me to find someone in your area please just let me know.
thanks,
joyce
Posted on Feb 07, 2009
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
What does F6 code mean?
F6 code means the control board can not detect the speed of the motor. The failure could be the motor or the MCU does not work.
Oct 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I had whirlpool duet wfw94hex0 error code f6 -e2
If it's the same as a UK version, F6 is a motor speed sense fault
Dec 23, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a F6 code problem with my Whirlpool Duet FL Washer, any ideas?
F6 is an issue with the motor drive tachometer. Most often this is caused by poor connections at the machine control or motor controller. Locate the main machine control by removing the top panel and the motor control by removing the rear panel. Remove each connector, ONE AT A TIME, and reinstall. If this does not work, you likely have a faulty control.
Kelly
May 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does "F6: mean on my front loading washer?
F/6 is a Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is an F6 on my duet washer? I already
three things.... could be the motor, could also be the MCU (  motor control unit ), could be the wiring harness .  check the wiring harness between the speed sensor at the motor and the MCU.  i have run into all of those being bad on different machines.
Aug 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We get an F6 message sometimes when the spin cycle is supposed to come on? any ideas
F6 = The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes.
1. Verify the shipping system including shipping bolts, spacers and cables are removed. 2. Unplug washer or disconnect power. 3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). 4. Plug in washer or reconnect power. 5. Check the MCU by looking for operations of the drive motor. 6. Check the drive motor for powered rotations.
Apr 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
323 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
