Question about Samsung WF203ANW Front Load Washer
Once the wash is done I can hear a great deal of water still in the tub as I spin to check for stuck cloths. how can i get all the water to drain?
  • 155 Answers
Check to see if you have a filter you can clean if not check the water pump it may have a filter on it if all clear check hose from tub to pump to see if anything is stuck like a sock or something if this is clear check outlet hose if still no problem you may have an inefficient water pump which will need to be replaced let me know how you go
Posted on Nov 12, 2009
I have a Whirlpool LHA 5700 old school washer. It works great. It wash clothes with no problems. It just stop spinning the water out tub and clothes. The water drains as far as it can but that's it. W
Don't know the model but with the old basics with electric motor drive as a 1st step always check for broken wires to the motor as they flop around a fair bit and eventually break them or corrode them from water and washing detergents.
Apr 19, 2014 | Whirlpool Washing Machines
My maytag neptune washing machine is not spinning out the water from my clothes once its done washing. My clothes are still soaked even after its done and theres a little bit of water left in the...
you have a partially blocked drain from the tub down thru the pump to the drain pipe,remove the lower front cover and remove the drain cleanout and check for blockages in these hoses
May 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
My washing machine isn't draing properly can hear the machine working but won't drain what might be the proble? Send me a email to: stixx_78@hotmail.com if you could please.
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Feb 04, 2010 | Washing Machines
Washer doesn't fully drain
Hello. Yes this is completely normal. Lots of people have this and they too think something is wrong. As long as there isn't water in the tub.
Here is a website for you to copy and paste into your address bar:
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm/printable
I think you will find this very knowledgeable!!!! Thank You
Aug 29, 2009 | Kenmore 22422 Top Load Washer
Washing machine will not drain. water wont drain
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 12, 2009 | LG WM2016C
Washing machine wont wash screen says test.
Its a draining problem.the drain pump is either got blocked so needs cleaning or the drain pump is faulty and needs replacement. --------------------------- If your washer won't drain, check these:
Jun 11, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Won't drain, cycle keeps on going
May 20, 2009 | Washing Machines
G.E. washing machine will not drain completely
It won't drain
good luck.....
Mar 28, 2009 | GE WJSR2080V
Water wont drain
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
**Take the front cover off and you will find brake pad pieces in the bottom.
Now some say you have to pull the center out to replace the pads...I don't. Here's how I do it..
Remove old screws were brake pads use to be and loose them! Kits comes with new screws that you must use. The transmission will turn free without the brake pads. You will need a 3/8 stubby ratchet. Insert 0ne pad in place toward the front and line up holes with front set of holes in mounting plate. NOW....spin trans around until the pad is near the back set of mounting holes. I use an Allen key to align holes and put rear screws in. Once you get the back one in the 2 front ones are easy. Don't forget to bring a new belt with you!!!!!!!!!!!!
NOTE:.....You must coat the new brake pads with a little silicone grease**
Dec 20, 2008 | Amana NAV5800A Top Load Washer
Washer not draining water
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Samsung WF203ANW Front Load Washer Logo
352 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
