Question about Haier XQB60-91BF Top Load Washer
Does not dreain water. Error code E1 says hose blocked or cut. Hose is fine, clear in and out. Water does not pump out?
  • 155 Answers
You may have an obstruction in your water pump take it out and have a look if it is free you have to check that the pump has power to it if not you may have to call a service man let me know how you went
Posted on Nov 12, 2009
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
WTL 5410 getting E1 error message. Condenser hose seems unblocked. Pool of water behind the heat exchanger
Dado
Jul 02, 2015 | Bosch Dryers
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Toshiba washing machine model AW 9790s error code E1
E1 is the drainage hose error, check the drainage pipe hose is not blocked damaged or filled with water or frozen, or maybe the return sensor for the hose is switched sensing something is wrong with the pipe but isnt. check the drainage hose ensure all water is out of the hose. open and close the lid one, then press the start/hold button this should reset the error alarm.
I hope this was useful
Feb 15, 2013 | Washing Machines
I w 812
Here are some details for fault code 37
37.
(00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3 minutes. There are three likely reasons for this fault. One is that the drain hose or the pressure switch hose has been squashed or kinked and the pump out rate has been dramatically reduced. The second possibility is that the pump is partially or fully blocked. The third is that the pump is not operating due to Motor Control Module, wiring or pump failure. This fault could also appear if the machine is pumping to an unusually high head of drain hose or into an extended length of drain hose. The fourth possibility is a diverter valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation mode, giving the module the appearance the pump is not lowering the water level.
Primary Source:
Action:1)
Pump System.
Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 39.36in / 1 metre extension hose of the same diameter fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the basket is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain hose is not blocked.
5) If the basket contains water, then service the pump from the top of
the machine by removing the top deck and inner basket. Bail out the water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action:
Tertiary Source:
Action:
1) Check the pump harness is connected correctly to the pump. 2) Check continuity of the pump harness.
Motor Control Module module.
Activate the pump by operating the machine in spin mode. Check the pump is rotating. If it is not operating, and Primary and Secondary checks have been performed, then replace the Motor Control Module.
Aug 19, 2012 | Fisher Paykel Eco IWL16
Fisher and Paykel GWL11 washer not going into rinse cycle, getting error code 37
Pump should read
110V AC pump 60Hz 7Ohms +/- 8% @ 20oC
230V AC pump 50Hz 33Ohms +/- 8% @ 20oC
37. (00100101) Pump Blocked Error (No change in the water level)
Primary Source: Pump System.
Action: 1) Check that the drain hose has not been kinked.
excessively long. A 1-metre extension hose of the same diameter
4) If the bowl is empty of water, remove the pump from the pump
5) If the bowl contains water, then service the pump from the top of
the machine by removing the top deck and inner bowl. Bail out the
Action: 1) Check the pump harness is connected correctly to the pump.
Tertiary Source: Motor Control Module.
Action: Activate the pump by operating the machine in spin mode. Check the
Jul 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have an 1E error code. The manual says a blocked water feed hose. Ive checked all hoses and they are fine. Good water pressure. No water restriction. Is there a water flow sensor or something in the line...
Hi
E1 is a leakage error in your LG dishwasher; it is usually displayed either due to a clogged drain or due to water leakage in hose connections. If the drain pump assembly is not clogged then check the motor water seal leakage of sump assembly and also check the impeller of washing pump, if it is worn then replace the impeller. You can also make sure that the height of drain hose is not over 20". Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code E1
E1...LEAKAGE ERROR-displayed-
The excessive RPM of
Washing Motor
happened during Wash
cycle due to water
leakage.
Water leakage in Hose connections.
Water is leaked by damages.
The Motor Water Seal leakage of
Sump assembly.
The height of Drain Hose connection
(sink-Drain Hose) is not over 20 .
Impeller of the Washing Pump is
worn away.
Replace the connections of Hose.
Check the point of damages and
repair or replace the related parts.
Read the Installation Instructions
(page 9) and fix it to the
recommended Height.
Replace the Impeller of the
Washing pump
this is from your manual any more questions please message me back thanks again
rickead1
Sep 02, 2010 | LG WM2487H Front Load Washer
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
Haier XQB60-91BF Top Load Washer Logo
211 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
