Question about Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840 D paper on manual feed jammed!
Hi - I inserted my paper on the manual feed, the paper went in and it gave me a paper jam error. I took the cartridge out and the bottom tray out and I can't find the paper - help!
  • Soulvisitor
    Soulvisitor May 11, 2010
    Have you opened up the back and checked the fuser(hotbit) at rear for concertined paper?
  • Anonymous Mar 29, 2014
    Paper feed sticking
I want printer driver for winxp
Posted on Apr 14, 2008
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
Hello, I have a Brother MFC-640CW that show a paper jam error message, but no paper jam in the printer. I have inspected the printer and can't find anything, how can I clear the error message, or repair...
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Nov 10, 2010 | Brother MFC-640CW All-In-One InkJet...
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Brother MFC 8460
Hi
There must still be a piece of paper in the machine check the fuser section at the rear of the machine maybe be piece there or check at the paper cassette area remove cassette and check that the paper hasn't got jammed as it feeds through.
Thanks
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Get paper jam error on Brother MFC 5840CN
are you using brother oem ink? generic ink gives lots of problems
Dec 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-8840D All-In-One Laser Printer Logo
708 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
