Question about Acer Aspire T135 PC Desktop
Hi i can figure out the volume on my acer aspire. it has been working before but now there is nothing coming from it. it is not muted and the volume setting suggests that it is actually on. any ideas?
Some time sound out put port bad or some driver mising u reinstall sound driver and try
Posted on Nov 12, 2009
Hi I have a acer Aspire 4535, windows 7 and i am having issues with the built in webcam now it worked for the first few weeks now nothing, I try to open it and it says that camera is not installed or...
Please find the below steps to access Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following: Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply. In the Audio Volume section, use the slider bar to increase the volume level. Verify that the notebook's volume is not muted. Pressing the Fn+End keys mutes the volume. Pressing the keys a second time restores the volume. Increase the notebook volume level by pressing the Fn+PgUp keys.
If the the above steps are not working, then follow the below steps:
You can reinstall the WebCam drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Acer Crystal Eye and install it
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Suyin) and download it.
Once downloaded install it on your computer.
If still facing the issue, then you may need to perform full system recovery, to do so please follow the steps mentioned below
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Feb 04, 2011 | Acer Aspire 4530-5889 Notebook PC
I am trying to get the cam for acer aspire 5920 to work without being on yahoo IM totake pics but it saids no problem with cam
Please access the Camera Assistant Software:
Thanks and regards,
Anil.B.R
Oct 31, 2010 | Acer Aspire 5610-4648 Notebook
Acer aspire 5536 crystal cam is not working on my windows 7
Please follow the steps below:
Thanks and regards,
Anil.B.R
Oct 27, 2010 | Acer Aspire 5536-5224 Notebook
I cant find my volumen keys on my acer aspire 5517
The physical volume keys on many laptops are either represented in the function keys (e.g. F1, F2, etc.) or sometimes in the arrow keys (on some Acers).
To use the keys, you need to press the blue [Fn] key (that is usually by the CTRL key) and then press the volume key on the function/arrow key to increase or decrease volume. There should also be a mute key that can be used similarly.
Feb 10, 2010 | Apevia Acer Aspire AS6530-5514 Laptop
Acer Aspire 6920 touch volume not working
aright what you gotta do is open up the "launch manager" which enables all the buttons found on the multimedia area plus else where to work perfectly. this even lets you program which applications you want to have when you press the other buttons
Jul 23, 2009 | Acer Aspire 6920 Notebook PC
Mic not working stilllll!
I'm not certain about yours, but my Acer Aspire 5920 has an audio/volume turn button, just under the lip of the laptop, just to the right of center. Even if you un-mute it, if the volume is turned down all the way - the button revolves, so looking a the front, turning it counter-clockwise will turn the volume down to off, and you won't hear a thing, no matter how much you try to un-mute the thing.
So turn that rotating button to the right, to make it louder, after you have un-muted a control panel volume slider and moved it up, and that just might make it work for you.
Jun 25, 2009 | Acer Aspire One PC Notebook
Audio problems Acer 5100-3583
Hi i would check that the drivers are up to date, also check to make sure that in the volume control the .wav files are not muted
Jan 23, 2009 | Acer Aspire 5100 Notebook
My acer aspire 5610z
Checking volume control for muted input/output devices
  1. Click Start, All Programs, Accessories
  2. Click Entertainment, Volume Control
  3. Ensure that all volume control levels are raised and any mute boxes unchecked, with the exception of the microphone.
Try this to see if it helps.
;0)
R-
Nov 06, 2007 | Acer Aspire 5610-4648 Notebook
Aspire 3628ANWXCi built in microphone
Go to your speaker icon in your task bar on right hand side and right click then on volume control. Go to file then select options/properties and then scroll down to the microphone on the show volume controls box and tick it. The microphone volume slider should now show and make sure the mute is unticked.
Jan 17, 2007 | Acer Aspire Notebook PC
Acer Aspire T135 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
