Question about HP OfficeJet 4255 All-In-One InkJet Printer
How can we use the printer while the fax is on? how to set up fax while printer is being used?
  • 591 Answers
What do you mean, "... while the Fax is on."? You can set the fax so it will automatically receive a fax, but while a fax is being processed (send or receive) you will not be able to use the printer for anything else. You can set up lots of things about the fax, but if you are printing the printer is pretty well busy doing that.
Posted on Nov 13, 2009
When receiving fax, it won't print
make sure the property settings for the fax are not on the Microsoft printer make sure it is set to the local usb printer
Jan 28, 2014 | Brother MFC-J625DW Wireless All-in-One...
Dell V715w wont receive faxes
To receive a fax automatically:
  1. On the printer control panel, press the Setup setup_icon%281%29.jpg button, then use the menu to select Fax Setup, Ringing and Answering, and then Auto Answer.
  2. Select On and then press OK to save the settings.
  3. Select Pick Up On and set the number of rings, then press OK to save the settings.
To receive a fax manually:
  2. Select Off and then press OK to save the settings.
  3. When the telephone rings and you hear fax tones when you pick up the handset, press the Start button on the printer or *9* on the telephone attached to the printer.
Oct 25, 2011 | Dell All-in-One Multifunctional (v715w)...
How can I cancel incoming fax on lexmar x646e
If the printer is connected to a network, get the IP address of the printer and access printers web interface. You may print a network settings page to get the IP address of your printer. Open a web browser and type the IP address on the address bar.
On the left side, click on the configuration menu and click on fax settings and select fax setup. Under fax receive settings, please uncheck enable fax receive.
You may also do this using the printer's operator panel. Just press on Menu button and select settings. Select fax settings and analog fax set up. Select fax receive settings and turn off enable fax receive then press submit.
Jun 20, 2011 | Lexmark X646e All-In-One Laser Printer
Which port to use for fax???? sonyajohnsonrn@yahoo.com
Followup the steps to setup the printer to send/receive fax.
Connect the phone line ( wire ) to Line 1 Ext at the back of printer port.
The connection is from the Phone socket to printer.
Press the Auto-Answer button on the front panel of the printer to enable automatic fax receiving.
If your no. of rings on voice mail or Answering machine is 4, you need to set 6 Rings to Answer on printer to receive the fax or else the printer will start accepting all the voice mail calls.
Press the Setup button on printer front panel
Scroll till you find Basic Fax settings Or Advanced Fax settings - Press OK
Choose the option Rings to Answer - Press OK
Set the No. of rings. - Press OK
Your printer is ready to send/receive Fax.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 02, 2010 | HP Photosmart C7280 Laser Printer
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Fax receiving problem
press the set up button or the tool button the printer . then use the right arrow or left arrow button scroll to basic fax set up ,and advance fax set up. u will find the distinctive ring pattern under advance fax setup. also check if u are using any telephone answering machine if using check the rings to answer in ur printer should be 2 rings higher than the rings to answer in the telephone answering machine.also turn off the error correction mode.turn the auto answer on.try this steps
Sep 11, 2009 | Office Equipment & Supplies
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Setup as fax
What you need to do to set up fax on most printers is use a standard phone cable. ( Cat 3 )
Plug one end intor the printer and the other end into a phone jack.
Then follow the instuctions on the manual to set up the fax number on the all in one printer.
With this printer you can also fax by using the microsoft software.
Here is the manual and it has step by step insturctions on how to set up faxing with software.
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
Nov 13, 2008 | Dell 924 All-in-One InkJet Printer
How can i receive fax on my printer
Your printer should have software to install for the fax. Then go to control panel and click the fax machine, check your connectivity settings and make sure the phones numbers are correct for out-going and the in-coming settings.
If you do not see the fax in printers then the fax part of the printer has not been installed, then install hardware, then software and use the install wizard if you have one. This helps too.
Jul 23, 2008 | Lexmark X6170 All-In-One InkJet Printer
Fax - Using Vonage
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off. Try sending FAX.
Dec 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 4255 All-In-One InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
