Question about Logitech X-540 Computer Speakers
Sound Shut Off
I just got these speakers and a new sound card and they work for the first 30 minutes or more the sound just stops, And my computer says everything is working properly.
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Stapley
Hello, there, well, it is a real problem but if you got warranty, use it, go ahead and change for a new pair of Speakers, or check connections, and the mixer, if all is up, and nothing on mute.
hope you can fix that!
Posted on Jan 08, 2008
    Problem Solver:
  • 7 Answers
I understood your problem...u cannt hear sound after listening for 30 min continuosly..so best way is listen songs for 28 min and shut down ur computer and again turn it on...thus can listen for 28 min more..do this as long as u wish to listen songs..
do remember,,,no gains,,no pains...
6ya staff
SOURCE:
Last week my computer crashed down. We can't contact the technician who used to fix our computer. Now we found a new one who can reformat our computer but this time, he installed windows 7. Now, our...
Make sure the speakers are hooked up properly and also that the sound card drivers are installed, you can verify this by going into the device manager. The main speaker wire has to be hooked up to the output of the computer sound card.
If the sound card drivers are installed and the speakers are hooked up properly and your still not getting sound, try the speakers on another computer that you know has sound. If the speakers work then its a sound card driver issue on the original computer. If the speakers don't work on another computer then you know the speakers are bad.
Apr 15, 2010 | Logitech X-240 Computer Speakers
Hi, They suddenly stopped working, think I
Try another speaker set.
If this does not fix it, then consider the sound card if it is removeable, get a new one. If it is internal, turn off the sound and install a sound card.
Oct 05, 2009 | Dell A525 Computer Speakers
New Sound Card is not working.
Ted, the first thing you should do is go into your computer's BIOS and disable the built-in sound card. Once you do that, go back to your device manager and if the onboard sound card still appears there remove or disable it. Then reboot and your new sound card should be recognized and you can install drivers and begin using it.
Apr 25, 2009 | Computers & Internet
Install new sound card. Creative tech
Before you install the sound card, you install the drivers for it. Drivers are small 'pieces' of software, that allow the Operating System to 'communicate' with the device. If you did not, then No, Windows did not recognize your sound card.
(In essence. Read on) (Not to insult your intelligence. Windows XP, is an example of an Operating System. So is Vista)
In this instance, the device is a Sound Card. Those drivers are on a CD, that should have been provided with the sound card.
Reasoning that you install the drivers first, then the Sound card is this,
When you install a device, Windows 'recognizes' it, as soon as Windows starts up. Windows 'breaks it's neck' to hurry up, and find drivers to match the device. If there are no actual drivers, then Windows chooses from Thousands of Generic drivers it has, and matches one up.
This is No good. The device needs THE drivers for it.
Then the owner comes along, and installs the drivers later. (Or in your case, didn't)
This causes a driver conflict.
BUT, you didn't indicate you installed the CD, therefore didn't install the drivers, and Windows is using the generic drivers. Crappy quality results.
Suggest you do this. Computer off, and unplugged
from the surge protector. Press the Power On button, and hold it in. Hold it in for a count of Five seconds, then let go. (And I mean Five at least. Count, 1001,..1002,..1003,..1004,..1005)
Do this procedure two more times.
What you are doing is clearing CMOS error codes, and resetting your BIOS, back to the factory default setting.
Computer unplugged, computer case open, touch the metal frame of the computer case. (Work on a table) This will relieve your body of Static electricity. Your body always carries static electricity. Static will silently fry out, your delicate computer hardware components.
Now take the sound card out. Leave the case open, plug the computer back into power. WAIT 1 minute, then turn the computer on. When Windows has fully loaded, install the CD for the sound card, Follow the instructions.
At the end, if it asks you do you want to restart your computer, NO!
Close all windows, until you are back at your desktop screen. Shut your computer down normally. (Start>Turn off computer>Shut Down)
Unplug the computer from power. Forget this part, and you may be buying a different computer.
Install the sound card. Close the computer case. Plug the computer back in. WAIT 1 minute. Turn the computer on.
Now how's your sound?
Apr 24, 2009 | Dell Dimension 4600 PC Desktop
I was about to install a PCI sound card TM P1018 in my cpu. How will i do it?
Shut down the computer. Unplug machine Disconnect all peripherals from the computer. Remove the cover of the chassis and lay computer on its side if it is a tower. Remove the back panel, if necessary. Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly. 8If the computer doesn't already have a sound card, find an open slot. 9Knock out or unscrew the metal plate on the card's slot holder on the back panel. Step10Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card. Step11Connect cables from the CD-ROM drive to the sound card. Step12Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole. Step13Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports. Step14Turn on the speakers and restart the computer. Step15If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel. Step16Play music CD to test sound card. Step17Shut down computer. Step18Replace cover of computer. Reboot computer.
Apr 24, 2009 | Computers & Internet
Speakers have stop having sound
1. Please plug in a set of speakers or headphones known to be in working order.
a. If the known-to-be-in-working order speakers or headphones work, your existing speakers are faulty.
b. if the known-to-be-in-working order speakers or headphones do not work, your existing speakers are fine, and your sound card is faulty.
Mar 29, 2009 | Computers & Internet
My computer has stop playin sound
1st make sure that your speaker or headset is working try it on other devices,If your speaker is ok,you nid to reinstall the sound card driver just go to your computer website(e.g. Dell,Acer etc.)just type the model no. of your PC then download the sound card driver, then install.2nd solution is to restore your PC back to the time when it's properly working.
Jan 24, 2009 | Creative Labs CT4870 / CT4780 Sound Card
How can i install a new Computer Speakers? I had some speakers on my computer and it stopped working. I thought my speakers were messed up so I got some new ones and now my computer says that there is no...
This sounds more like a sound card issue. Go to Control Panel, System, Device Manager and check your sound card.
The speakers get plugged into the audio output jack on the back of your computer.
Jun 03, 2008 | Audio Players & Recorders
Center speaker channel
This sounds like a bad connection inside the receiver. A 5 minute fix with a soldering iron and about 30 minutes to get to it.
If you can solder you should be able to fix this yourself.
Dan
May 23, 2008 | Yamaha Digital Sound Projector YSP-800S -...
Sound from 4 speakers cut off..
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 20, 2008 | Logitech Z-5500 Computer Speakers
Logitech X-540 Computer Speakers Logo
73 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
