Question about Proform 530 Treadmill Walking Belt
My belt runs but stops as soon I step on it. - Proform 530 Treadmill Walking Belt
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 103 Answers
More than likely your drive belt needs to be tightened. Lower cover needs to be removed to access this drive belt.
Posted on Nov 13, 2009
Belt stops when stepped on
sounds like the belt is loose.there are bolts at the back on either side that tighten or loosen the belt.adjust with belt running about 3mph. tighten both bolts about 1/4 turn each while watching the belt to make sure it is centered. give it about 15 seconds after you tighten to see the adjustment that u make.the walking belt should only be able to lift up a little bit like 1 inch. you shouldn't be able to get ur hand all the way under belt (not running of course).
Apr 09, 2014 | Nordic Track NordicTrack A2750 Pro...
Life step 9100
please see the video and lube too rollers bearing front+back+test the drivel belt motor, and replace if necessary the belt.
God bless you
Jul 07, 2013 | Exercise & Fitness
My Horizon CT 7.0 treadmill slows down when i step on it
LUBE THE deck belt and rollers bearing . This happen because you must lube about 150 miles aprox. See the video and fix it. However if the problem persist. Time to replace the old board deck.
God bless you
Jan 25, 2013 | Horizon CT7.0 Motor Control Board
Treadmill run normally when switched on, but as soon as you step on it, it stops
two things either the tension on the walking belt is really lose. or your motor belt is worn badly. check under the hood.
Mar 07, 2011 | Reebok Rt1000 Treadmill Walking Belt
Belt squeaking and hesitating when I run
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust. Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts. Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5. Step 4- If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5. Step 5- If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced. Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position
Jun 02, 2010 | Proform Exercise & Fitness
When I step on the treadmill, the runner stops and
Unplug unit then remove motor shroud the walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting..
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step If your treadmill is equipped with this bolt (very few are) the repair will only require one person.
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 27, 2010 | Proform 575 Crosstrainer Treadmill
The treadmill stops as soon as I step on it. It makes a loud noise and stops. Once I get off it starts to run again.
read in manual on 2nd page in grey area # 3, 4,7 IF THAT IS NOT THE ISSUE, then 2nd question, how old is item, from what you stated, if weight of user not issue and item is fairly new, sounds like mtr dr. belt slipping/loose. can be tightned up like belt on car-under the hood-but if under manufactures warranties, best call them first!!
Jan 06, 2010 | Proform 775 Crosstrainer Treadmill - Free...
I have a proform treadmill that slips as soon as i step on track i looked at the belt it looks good how do i tighten up the track
There should be adjustment screws on the back left and right sides. The screws will be horizontal with the tread, and probably need an allen wrench to tighten. If the tread runs straight, tighten each side 1/4 turn at a time to keep them even. Check the tread after each adjustment, and stop as soon as the tread quits slipping.
Sep 08, 2009 | Proform Crosswalk 500 Treadmill
Proform 530 Treadmill Walking Belt Logo
395 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
