Question about RIM Blackberry Curve 8300
Blackberry curve will not turn on but red light goes off then on
  • 561 Answers
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Posted on Jan 12, 2010
4 Suggested Answers
  • 113 Answers
SOURCE: Blackberry Curve 8310 LCD Screen won't turn on
You can find Video Disassembly Instructions at
www.fonlogix.us
They have New LCD's for the cheapest price.
Here is a Coupon code for 10% off at their site
Code: Fixya10
Posted on Jan 31, 2009
Bajanguru
  • 7752 Answers
SOURCE: Blackberry Curve won't turn on, red light with lit screen
just follow these steps to fix it
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Posted on Jan 30, 2010
Bajanguru
  • 7752 Answers
SOURCE: blackberry isn't turning on
Try this method it works
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic device. Try drying it with a desiccant and replacing the battery. If there is no activity, you can still try the last ditch technique, nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way of saying, the last thread has terminated, the OS has halted because it is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows,
If that fails to connect, there is one final solution. Go Old Skool ...
The good news, starting from scratch, you will be back in service in a couple of hours. biggrin.gif
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
Posted on Feb 04, 2010
BB curve 8520 will not start
Good chance the unit is either broken and not allowing the Operating System (OS) to run. Next step would be to download/install Blackberry Desktop Manager (for this version of Blackberry) from the Blackberry website. Connect the Blackberry to the PC running Desktop Manager and see if the Desktop Manager can connect to the Blackberry. If yes, you could try to update the OS.
Jan 05, 2014 | RIM BlackBerry Cell Phones
Hello, I was trying to set a password on my Blackberry 8520 when I locked iy phone it said cleaning history, then turned off. 3 Hours later it is still trying to turn on. I have taken the battery out...
Try to reset your blackberry password by entering wrong password 10 times, it will make your blackberry curve 8310 unlocked as well as your previous data will be erased. After your blackberry unlocked, you can setup new password for your phone.
Apr 03, 2011 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
May 17, 2010 | RIM BlackBerry Curve 8520 Smartphone
My blackberry 8310 died and wontt turn back on..i charge itt and the lcd red light just comes on
can u c the battery sign after the led light goes off with a red line or with a charging line?
Apr 25, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry 8310 curve wont turn on!
take out the battery and put it back in after about a minute
Dec 29, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry Curve 8330 won't turn back on
Pull the battery out and put back in. Then hit the reset button on back panel.
Sep 05, 2009 | AT&T Blackberry Curve 8300 Smartphone
My blackberry won't turn on.
I have a brand new blackberry put it on charge and there is no red light at all indicating its charging is that a faulty charger or phone?
Apr 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Red light goes on then turns off. phone will not turn back on.
There are only 2 options:
- faulty firmware: reload the firmware with App Loader in Blackberry Desktop Manager
- damaged motherboard: then the only thing you can do is to replace the motherboard, but this is usually more expensive than buying another one
Oct 09, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM Blackberry Curve 8300 Logo
1,131 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
