Question about Panasonic KX-T7630 Corded Phone
Taking the call from the extension
The KX-T7630 central telephone system is in a locked room, then it rings. there are about 6 extension phones. How can i pick up the call from the main telephone using the extension phone? I know from previous knowledge of this kind of system that you just have to press a number combination from the extension phone and there you have it, you can pick up the call from any extension phone. could anyone tell me how it would be? thanks.
Try *41 followed by extension number
OR *40 followed by group number eg 00 or 01
Posted on Mar 27, 2008
My Panasonic Phone KX-T7630 rings seventeen (17) times before going to voice-mail. Desired amount of rings before going to voice-mail is four (4) to five (5).
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
Jun 28, 2011 | Panasonic KX-T7630 Corded Phone
I used to have the Panasonic KX-T7630 system in the office building we sold. I no longer have the capability of setting the entire system up - is there a way to use the phone as just a regular desk phone...
The KX-T7630 is a proprietary digital phone that will only work on panasonic phone systems. You need an analog phone if you are going to connect it directly to an outside telephone line.
Jan 19, 2011 | Panasonic KX-T7630 Corded Phone
Cannot go to voice mail to check my old voice mail from PANASONIC kx-t7630
If your old phone was an extension on the system and it is a TVA voice mail product, you dial the VM access code (usually 500) and when it answers you dial #6 * and your old extension.
You now appear as you would have if you had pressed MESSAGE or dialed 500 from your old phone.
Carl
Sep 27, 2010 | Panasonic KX-T7630 Corded Phone
Hello, I'm trying to turn the ringer off some of the phones at my work. We have panasonic kx-t7630 phones. Are you able to help me please?
When you bought the phone system, it was either installed by a professional installer, or you got some sort of instructions. A Panasonic phone system of the TDA/TDE/NCP type rings phones by Incoming Call Distribution Groups (ICD). The main group is 1 and usually is numbered 601. Extensions are members of an ICD group(s) and the number of rings can be programmed for No Ring, Immediate ring, or delayed rings of 1-6.
You can turn off the ringing, but keep in mind that CallerID only displays on a ringing phone or after you answer it. So, if you somehow have access to program 620 and 621, then you can change it from a phone, if not, you'll need access to the maintenance console of your particular phone system.
I don't wish navigating in 620/621 from a phone on my worst enemy and it's beyond the scope of a free forum to instruct you on how it works. I suggest you call your Panasonic service tech.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
How do I change names that are programmed into the phone?
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 004 and then ENTER.
3. Enter the extension number you want to change.
4. Enter the name (the same way as texting on a cellphone)
5. To save the changes press AUTO DIAL / STORE.
6. To go to the next extension press NEXT on the screen.
7. Lift the handset and put it down to exit program mode.
Mar 16, 2010 | Panasonic KX-T7630 Corded Phone
Extention Names?
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system -
4. Enter the name (the same way as texting on a cellphone.)
Feb 18, 2010 | Panasonic KX-T7630 Corded Phone
When I try to hook a second kx-t7630 to another (parallel) I can make outgoing calls but cannot answer them.
I'm guessing you're using the Digital XDP port. Each of the phones has an extension and that 2nd extension number has to be added to the ICD group as a phone for the lines to blink or ring on the 2nd phone.
It requires system programming.
Carl
Sep 24, 2009 | Panasonic KX-T7630 Corded Phone
I attached one t7630 to another (parallel). The
Parallel is just a method of connecting phones. It has its own set of programming, both extension number, class of service, and ringing.
If you have access to system programming, you can add this phone to an ICD group with the other extensions. If not, you'll have to get in touch with your installer/dealer to make the changes.
Carl
How do I change the name display on my extensions
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Feb 12, 2009 | Panasonic KX-T7630 Corded Phone
Programming help
THANK YOU
Dec 23, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
321 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
