Question about Logitech Webcam
Hi there my webcam has a built in mic but i cant
I can get the picture just no sound i have plugged the usb in there is another lead as well, I don't know where it goes as i have surround sound
    President:
  • 2,049 Answers
It goes into the microphone jack...
Posted on Nov 12, 2009
I just recieved my cam usb hype webcam and on box it says vista compateable but i cant get it to work at all why
thanks for taking time to report this issue, please do answer the following questions:
1. Did you try updating it?
2. What service pack of Vista are you using?
Feb 08, 2013 | Hype Communications MobiCam WebCam
The microphone on my ic014c webcam won't work!
if the microphone has a second cable with a jack plug ..than you have to use it in the pink inlet on the sound card ..and will work ..or in the mic in of the laptop ..
If there is no second cable (split cable ) with jack plug ..it means the mic is using the usb ..and in this case you have to get to the sound settings and select the usb for the mic ..Also select the usb for each instant messaging programs you use..to d that just open the program ...get to the tool options ..and select sound devices and under mic select the usb instead of regular windows default or sound driver ..
Dec 23, 2011 | Computers & Internet
My original question was "do
No, just go through your skype setting testing you microphone, if there's not one built into your laptop (Check user guide) then you need an external one.
You may also need to check the sound configuration on your laptop, make sure that the Microphone is turned on.
Mar 12, 2011 | Acer Aspire 5500 5570-2609 Laptop
How do u get hsm wii microphone to work on
well ..i cant see what type of conection you mic has and what you really want to achieve as far as quality of sound or ultimate use..,but...here are some ideas.. A mic needs a pre amp and that is often built into some cheap but usable mini mixers made by behringer..You could pick up one and a good cheap dynamic mic[dynamic mics are best close to the sound source] with a lead and then go from the main output of the little mixer to the audio input of the computer.. A second but easier way and one that could give very good results is purchase a USB input microphone and this will have mic pre amp built in so it just plugs into your computer usb port.. SE electronics ,Rode make brilliant ones that are used often for podcasting..[well worth the +-100 uk pounds] but i am confident that berhinger will make a usable model for much less money[these type usb condensers will be sensitive and give clear results]...
Mar 21, 2010 | Logitech Vantage USB Microphone for...
When recording soud nothing from the speskers
go to your recording properties and see mic is selected and the volume levels are not muted. Also is it a normal mic or usb mic?
Jul 24, 2009 | Microsoft LifeCam Show Webcam - 2.0...
Does Gateway one usually have a built in mic?
yes most laptops do have a built in mic however you do need to turn on the mic in your sound control section. If you have more questions let me know I will help you further.
Jun 17, 2009 | Computers & Internet
We cant record a video clip with sound - only picture
You need to go into the recorder options ant tell it the sound source to us is the USB Mic. on the webcam, or what ever the source of the Mic. is. There are several sources in Skype that allow changes to be made. Use the drop down menu for the selection and select the one you are using for the mic. Good Luck, RAC
Mar 28, 2009 | Logitech QuickCam Connect Webcam
I don't know how to turn on my web cam and make a video
hi im josh in cebu phils. may i help you friend? to turn on your web cam. first you need to plug in the usb connector cable built in your cam and also the mic.plug to the pink slot for  mic. and usb for usb socket at the back or in front of your pc if available then you install the cd driver built with your cam.you install the driver completely then you reboot your pc.after rebooting you will see the icon zoom and cam in the desktop, you may click then bang! Problem solved. good luck friend. please vote me so that i will know if i helped you so.
Feb 23, 2009 | Logitech Webcam
No sound with my Cyber Snipa Scout Personal Webcam
Most webcams doesn't include a mic. You should have two wires if you do have a built in microphone. One USB and the other is for the mic input. If it doesn't have a mic, they can be purchased separately.
Jan 29, 2009 | Computers & Internet
No sound when connected on aim
Is your microphone integrated into your webcam? Make sure the correct device is selected. Go into Edit, Settings, Enhanced IM. Under Audio and Video, make sure the Microphone device selected is a functioning mic, such as Logitech Mic, or if using a headset, select the USB headset (if usb) or your sound card if using a mic plugged into your built in or add-on sound card.
Dec 01, 2008 | Logitech QuickCam Connect Webcam
Logitech Webcam Logo
70 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
