Question about Jenn-Air JED8430 Electric Cooktop
How do you seal the edge around the flat glasstop range, so stuff doesn't run underneath it?
    Problem Solver:
  • 9 Answers
Get fire-proof silicon and run a bead around the outside of the range and whatever your range is sitting in, e.g. bench-top.
Posted on Nov 14, 2009
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
Tip
Best way to Fix Scratches on Your Radiant Smooth top Cooktop
Cooktops are in many homes and are a preferred kitchen appliance to many home owners. The Cook in the kitchen can appreciate the stylish look of a sleek radiant smooth top Cooktop . Many invest top dollar to have stainless steel appliances including the following: Refrigerator, Dishwasher and Compactor. Moreover, having a sharp looking Cooktop addition only compliments the style and design of any high end kitchen. Maintainence and care of such an essential attractive appliance such as a cooktop is important.
Here is the best way to fix scratches on your Radiant Smooth top Cooktop:
Step 1 - Prepare your Cooktop by cleaning the surface*Make sure the surface is cooled* Use a damp rag first and sweep of crumbs and food stuff. Use your favorite cleaner and rinse completely. Careful not to get moisture around knobs or switches. Dry off surface.
Step 2 -- Work on the scratch area
Run the sharp edge of a razor over the scratch around 3x and this will aid in smoothing out any raised ruff edges. Apply gentle pressure to the cooktop scratch area.
Step 3 - Apply A Cooktop Cleaner
Use a few drops of cooktop cleaner to the scratch area. Use a sponge to rub in cleaner. Use circular motions to allow scratch to absorb product. Run the razor edge over scratch again making sure not to apply to much pressure.
Step 4 -- Clean Cooktop surface again and remove cleaning product
Rise off cleaner and dry with a dry paper towel. Inspect scratch to test results. Repeat step 3 until you have desired results.
Special Note* Their are many ceramic cleaning products to choose from and many claim to be the best on the market. Be sure to choose one that has good reviews and then test the results. Special attention must be given to all radiant smooth top cooktops. Be sure to use only cookware that is recommend by the manufacturer. And be sure to clean spills as soon the cooktop is cooled to keep the appliance looking well. Deep scratches or pits cannot be removed or buffed out and may lead to a cracked cooktop.
on Dec 16, 2010 | Kenmore Elite 44173 30 in. Electric...
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
Can you use metal cookware on the old Corning Glasstop ranges? If not, what do you recommend?
Yes. I use metal pots and pans on mine for years. They need a flat bottom. Heavey bottomed pans work best - Thin pans don't transmit the heat well,
Mar 09, 2011 | Verona 34 in. CTG536S Gas Cooktop
We are installing a new cooking top on our kitchen bench, do we have to put celastic around the edge, or will the foam strip underneath be ok,
Foam will allow liquids including oils to seep to the wood beneath the formica causing swelling then separation. Use a good sealant recommended by your local hardware store. Quite easy to apply and worth the extra $$$.
Mar 07, 2010 | Cooktops
Black spot on glasstop Kenmore stove
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Cooktops
Jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
Feb 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Cleaning glass cooktop
Hi, Any good glass/ceramic cooktop cleaner will do the job. Any grease spots or burned food spots can be scraped off with a razor scraper ( just keep it flat ) Use a couple of paper towels and put a dime sized drop of the cleaner on each burner and with a circular motion buff the top like you would wax a car, when cleaned up, flip the towels over and buff to a shine. I don't endorse any products but there are some that contain everything you need, cleaner , scraper, cloth like Ceramabrite. They can be found at most grocery, diy and some hardware stores. Good Luck!
Feb 06, 2009 | Neff 23 in. T1252 Electric Cooktop
Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
Apr 07, 2008 | Cooktops
Jenn-Air JED8430 Electric Cooktop Logo
429 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
