Play back problem of CD/DVD
First played well, but another time some portion of the video track is missing and system hungup. How many more repeat playing will result in more errors
  • 1,601 Answers
Your laser lense is probably dirty. They have cd/dvd lense cleaners.
If that dont work then the player is on its way out.
Posted on Jan 07, 2008
I am using this to play my newborns nursery CDs and was wondering if there is a repeat function. I don't want his cd to stop after the last song, and can't seem to find that function. I do not know if I am...
Repeat play (Remote control only)
Press [FM MODE/REPEAT] on the remote
control before or during play.
The player will play all the tracks or all the
programmed tracks repeatedly. " " appears
on the display.
To cancel repeat play, press [FM MODE/
REPEAT] again. " " disappears.
Hope this helps you!
Mar 14, 2011 | Sanyo AWM-660 CD Shelf System
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
I have a Yamaha TSX-130. Won't play CD when alarm set.
hi go to the alarm option in your system and diable the repeat option and enable play all it will work thank u
Aug 24, 2009 | Yamaha TSX-130BL Desktop Audio System ...
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Magnavox MWD 2205 DVD/VCR combo: DVD only plays first couple of minutes of disk and then repeats same over and over
is this the begining of a dvd that plays the introduction over and over untill you press play again or select the play option on the intrduction? if not then try a cleaning cd for the laser , also make sure the repeat option has not be enabled when the dvd is played hope this helps! I'll check back to see if you need more help
Oct 24, 2008 | Philips Magnavox DVD/VCR Dual Player
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Magnavox DVD Video Player DVD609AT
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• Compact Disc-Interactive
• Compact Disc-Recordable
• Digital Video Disc-Video
Recordable (DVD-VR)
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
12 cm
12 cm
Approx. 4 hours
Approx. 8 hours
Approx. 80 minutes
Approx. 160 minutes
20 minutes
8 cm
8 cm
Disc Type Contents Playback Time
Disc Size
74 minutes
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
Recordable (DVD-VR)
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
What video formats can you play with slv-d360p?
Hi al - your unit can play the following formats:
DVD -R / - RW
DVD +R / +RW
CD -R / -RW
The player can play CD-ROMs/CD-Rs/CD-RWs recorded in the following formats:
- music CD format
- video CD format
- MP3 audio tracks and JPEG image files of format conforming
to ISO 9660 * Level 1/Level 2, or its' extended format, Joliet Kodak Picture CD format.
*(A logical format of files and folders on CD-ROMs defined by ISO)
The player can play DVD-ROMs/DVD*RWs/DVD+Rs/DVD-Rs recorded in the following formats :
- MP3 audio tracks and JPEG image files of format conforming to UDF(Universal Disk Format).
In other words, just about everything. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
May 12, 2008 | Sony SLV-D360P DVD Player/VCR
Player will only play track #1
Maybe your "play once" option or "repeat" option is activated, try and check it and get it back to normal play...
Dec 03, 2007 | Memorex MPD8506 Personal CD Player
Computers & Internet Logo
David Payne
David Payne
