Question about Kitchen Appliances - Others
How do I replace the drainage hose on the LG LDF6810WW dishwasher?
  • 155 Answers
Which ever side the hose is coming out of remove that side panel you will be able to see the water pump and work it out from there.let me know how you went.
Posted on Nov 12, 2009
Lg d/washer about 8yrs old Oe code. Checked grey wire thiery. Cleaned hose filter etc. Was working fine moved house.Whats next.
A drainage problem causes "OE" to be displayed on the digital display panel. The drain hose is likely kinked, clogged or frozen. Inspect the hose and remove kinks. Unclog the hose, if needed. Replace the hose if the problem is not resolved. If the dishwasher still does not drain,
Feb 23, 2015 | LG Washing Machines
What do i do to fix error code OE on my LG dishwasher
Based on what it mentioned on the LG website it is an error indicating a drainage error. The solution might be to clean the drain filters at the base, check drain hose under kitchen sink and behind dishwasher for kinks or blockages. On make sure the kitchen sink drain is not blocked. Worst scenario is a clogged drain pump. you will have to provide the model number for any further analysis.
Sep 19, 2014 | LG Dishwashers
Ld14aw3 error code 0e lg dishwasher
LD 14AW3 Service Manual pdf
Mike - Here is the service manual.
Use - ld14aw3
Apr 07, 2014 | Dishwashers
OE error code on LG MODEL lds5040st DISHWASHER
drainage problem The pump impeller might be jammed or the drain hose is kinked or blocked or a bad pump Hope this helps
Dec 05, 2013 | LG Dishwashers
Keeps stopping and showing OE
Hi tpearsgolf,
The "OE" error code you are seeing, means "Outlet Error"
The drain pump is either clogged, or the outlet hose has been kinked.
- Inspect the Drainage hose at the back for kinks. - If any, straighten the hose
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it. You can remove the filter, as well as the metalish sieve underneath it, check the sump underneath near the drainage holes, make sure nothing is obstructing the flow out of the machine from there.
If not successful, you will need to replace the Drain Pump.
Kind Regards :-)
If you found this solution helpful, please rate it.
Jun 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
Dishwasher will no longer drain completely
The pump is bad and needs to be replaced. The pump is not pumping out all the water from the system
May 05, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher Model: LDS5811ST getting error code: 0E
OE is a drainage problem...check for twist or obstruction in drain hose .. make sure filter screen is clear... Hope this helps..
Sep 17, 2008 | LG Dishwashers
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
