Question about HP Pavilion dv6000z Notebook
The microphone is not working on my Compaq c700 What's wrong with it, I change three mics still not worked. Setting properties still not worked!
  • 1 more comment
  • supoj37 Nov 12, 2009
    yes I did plugged in with the correct jack and I checked my audio setting the unmuted is on and volume is max! The notebook is crazy that when I plugged in the headphone set, the sound should not come out from its speaker but it synchronized with the headphone sound. I tried to mute it, it didn't work.
    my compaq presario C700
  • Bill Schilz
    Bill Schilz May 11, 2010
    Have you installed it using a driver from the mic manufacturer? I know it sounds stupid, but you're sure it's plugged in to the correct jack? You've checked your audio settings and it's not on mute?
  • HP Master
  • 4,924 Answers
Ok ...you have to enable it in the volume manager ...so ...double clic on the volume icon tray ( lower right ) and will appear a window with a few volume controls ...In the left upper there is a option choice .....click and choose properties... in there you have to select the mic from a list ...its volume will be displayed on the initial window after that ...check not to be muted...and give it volume ...it has to work now ....
by the way I assumed that ya have an xp on it ...but its about the same for vista ..you have to go on volume controls from sounds...and see the playback properties...and volume and see not to be muted...
I also noticed that dowgrading from vista to xp ...for some HD laptops the mic problems are present ...It something with the driver ....if that what i said not working ... look for a more compatible sound driver ..or ...choose a usb mic ...maybe will do the trick
Posted on Nov 12, 2009
Testimonial: "thanks for the tips, I tried but it still didn't work out. Everything is unmuted and the volume is on max. Is that may be the jack of the mic itsel"
  • 2 more comments
  • Catalin Turcu
    Catalin Turcu Nov 12, 2009
    no ..it is not the jack ...however it is a posibility ...in regards with your comment that it muting the speakers,,when you plug into the headphones..this is normal cause the muting device for the headphones is a mecanical one in the outlet ...and no matter what 3,2 jack you plug it will mute the sound...in regards with the problem ..I suspect that the driver is just a compatible one ...and not the right one ...so ...let me know the exact model of your laptop ..and the operation system you use...and I will look for some forums to see solutions others done ...cause as I said before I did had the same problems with a similar Hp ....not sure about the series...but it behaved the same ....it came with vista on ...and when dowwngraded to xp ...it never worked the mic built in ...or jacked...until I found a driver that fixed it ....so ...even if will take me a while to locate ..I promise to link it ...
    Have a nice day !
  • Catalin Turcu
    http://h10025.www1.hp.com/ewfrf/wc/softw...
    this location will provide the best drivers for Vista ..
    ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32823.exe
    http://www.mediafire.com/?9duyqzcxwyh
    the other 2 ones are for xp ...you forgot to tell me what is you operating system ...anyway it's good to have them both ...ones never know ...when it will be needed..
    so ...uninstall your driver ...and install again ...after that look where I told you before to initiate the mic..from the options on the volume manager ( double click on the genera volume icon in the tray system )
  • Catalin Turcu
  • Catalin Turcu
    Catalin Turcu Nov 14, 2009
    did I mention that it might need a UAA fix..I believe it sa driver for some models in xp ..to make it work...you have to install it along with the sound driver ...
    http://drivers.softpedia.com/progDownloa...
    I have read about somewhere and I thought it is worth to gave it a try ...as I mentioned I did have some problems before with mic in downgrade from vista to xp ...and I let it be .....another try might be a usb mic to get along with ...if you have a camera that have a mic ..but its not a jack plug ...gave it a try ..
My compaq presario c700 xp microphon are muted.how to unmuted microphone.
Select the volume icon in the lower tool tray (looks a small speaker) then right click it - select "audio Properties" then "voice" - make sure the correct microphone is selected under "Voice Recording". This will also let you see the volume setting etc and is very easy to work out what is going on - there is even a hardware check option that will let you try the microphone after changing any settings.
Mar 18, 2011 | Compaq Audio Players & Recorders
Laptop compaq presario c700 model no 791tu camera and speaker working but mic not working(mic meter doesn't move) operating XP sp2.trouble shooting in setting chat says :working properly.early reply...
Dear sheetaldevbr,
Try to connect you video set (cam,speaker,Mic set) to another computer, to find out that probably the problem is in your Laptop PC. Or try to reconfigure your microphone by setting them up on Control panel.
Follow these steps:
Start>ControlPanel>Sound,Speech and Audio Device and rearrange your Mic Device driver. Or If you run the complete Office (at least 2003) try to run the speech recognition on office and run the training and you can also reconfigure your mic in Micrososft Office software.
GoodLuck!
Best regards,
bionic23
Dec 11, 2009 | Compaq Computers & Internet
Microphone not working for presario c700
If it has Realtek device drivers check through that not WDM. Also, make sure you set the record settings for the mic to select it, not the play settings.
Jul 25, 2009 | Compaq Presario 700 470024-192 Notebook
Inbuilt microphone of hp presario c700 not working
At first let me tell you should have Operating System Vista for the inbuilt mic to work to get the full performance as it has the drivers. Got to Start>All Programs>Accessories>Entertainmnet>Sound Recorder. You can check the mic is working or not.
Regards
Jun 18, 2009 | Compaq Presario 700 470024-192 Notebook
External Microphone on Compaq C700 series don't work.
just check in BIOS whether the setting for the external microphone is on or not.
Apr 10, 2009 | HP Compaq Presario C700T
Microphone is not working
i have compaq Presario c700 laptop
but my external microphone is not working & also inbuilt microphone is not working.
Feb 02, 2009 | Compaq Presario 700 470024-192 Notebook
control panel sounds audio device check microphone turned on,
find type of mic try to find drivers
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Having compaq presario c700 facing cound problem......
hey!
we have to face it, the microphone feature is not working on XP. i've tried to install it a millionth times, no go. it's working very well on vista. if you want, you can just try to do dual boot. both XP and Vista in one system. just a suggestion though...
Hope this helps!
Thanks,
Karlox™ :)
Jun 06, 2008 | Compaq Presario 700 470024-192 Notebook
Microphone Presario C700 not working
Just download audio driver from this link
http://www.mmoogle.org/compaqc751nrwindowsxpdrivershowto
I am sure it will work.
May 02, 2008 | Compaq Presario 700 470024-192 Notebook
HP Pavilion dv6000z Notebook Logo
279 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
