Question about Cameras
I have fuzz in the view finder of Olympus Evolt 410 I have cleaned mirror and have removed the upper lens and spring clips interior and cleaned that upper glass as well
Ron-C
  • 5 Answers
SOURCE: mirror problems
Could be 1 of two things: 1. Mirror linkage failed. 2. Something is holding the mirror; sticky foam or the lubrication has dried out. Remove the lens, use slow shutter speed to release the shutter. While mirror is stuck in the up position, very gently pull down on the front edge of the mirror. If it frees up immediately it was stuck on the foam. Might be able to see a mark on edge of mirror from the foam. Hope this helps.
Posted on Apr 23, 2007
jackboy
  • 2985 Answers
SOURCE: EVOLT E-500 LCD Problem (Mirror Image)
This is new one one. It would seem to be an electronic failure of some sort Suggest you refer to Olympus Support on this one
Posted on Aug 20, 2007
  • 8 Answers
SOURCE: olympus evolt 410
this is when the camera doesn't have enough light for auto focus! to suppress it, disable the option "auto pop-up" in the settings menu of the camera. you then might risk unsharp images but strobing won't happen until you manually pop-up the built in flash.
to get rid of the whole thing, you can buy one of the olympus e-system external flashes like fl-36 or fl-50. these bring a red-light for auto focus assistance.
Posted on Feb 29, 2008
  • 8 Answers
SOURCE: viewfinder's image is blurry
there's a little plastic screw right besides the viewfinder, i think it's on the right side. try to adjust sharpness with this screw (it's actually for people with glasses, allowing them to take pictures without wearing the glasses).
SOURCE: olympus evolt 410 flash
Turn of "AF Illumination" and it will get rid of it and not cause you other shooting problems.
Posted on Apr 17, 2008
The view finder darkens every time i take pictures
That's how a DSLR camera works. When you are setting up the shot, the image through the lens is reflected by a mirror up to the viewfinder. When you snap the picture, the mirror flips out of the way so the image can be registered on the sensor and then the mirror flips back. So, for that time, there is no image in the viewfinder.
Jan 07, 2011 | Olympus EVOLT E-500 Digital Camera
Olympus E-410 won't make a second picture
Try this: remove the lens, clean the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol. re-mount the lens. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. Try it and let me know the results.
Jul 11, 2010 | Olympus EVOLT E-410 Digital Camera
Mirror locked in up position on olympus e410
Go into the menu and find "reset"...follow the on-screen instructions.
Jan 27, 2010 | Olympus EVOLT E-410 Digital Camera
Telescoping lens opens but the view finder continues to flash an orange light and I can not push the button and take a picture. I have ordered a new battery to see if that helps because the camera is used...
Before trying the new battery, try cleaning the battery compartment contacts with a cotton swab dampened, not drenched, in rubbing alcohol. Blow dry the compartment and then try the new battery. Thanks, Dana
Jan 06, 2010 | Olympus Stylus 410 / ? 410 Digital Camera
Olympus E410 viewfinder problem
As far as I am aware, you can use the viewfinder OR the live view, but not both at the same time.
This is because a mirror has to flip up out of the way to reveal the sensor for the live view to work, and the mirror needs to be in the down position to reflect the image into the viewfinder.
Switch between the two modes and double-check if there is a problem.
Also try removing the lens from the camera and checking the position of the mirror. It could be that it has got stuck in the up osition.
Hope this helps!
Jun 27, 2009 | Olympus EVOLT E-410 Digital Camera
Olympus E410 mirror locked up
Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $282.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 18, 2009 | Olympus EVOLT E-410 Digital Camera
Olympus Cameras
You can use the lens from your old OM camera on the EVOLT E-410. You would need to purchase an MF-OM-1 adapter to make those lenses fit the new digital SLR camera. Also when using those lenses the camera would need to be used in Manual mode as there is no auto focus capability when using the old OM lenses.
Mar 28, 2009 | Olympus FE-230 Digital Camera
Mirror of my evolt E-410 is stuck in the up position
control panel not working correctly... send for repair
Oct 06, 2008 | Olympus EVOLT E-410 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
