Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
THE STAIR HANDLE WILL NOT SQUIRT WATER AND/CLEANING SOLUTION
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
The hose or nozzle could be plugged. The hose can be disconnected at the machine end there is a clip on the bottom of the connection. The fluid is dispensed by a pump which could be bad. If you disconnect the hose and put a rag at the opening to catch the fluid, then turn the machine on briefly the fluid should squirt out if the pump is working.
Posted on Nov 15, 2009
Cant put handle back on
Sometimes the hose that slides on the inside of the handle is coming undone. You will need a new hose.
Sep 05, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
No spray onto carpet
You might have a clog in the heater. The upholstery tool water does not go through the heater. You will have to access. The heater and remove the cover to clean out the channels in the heater
Mar 04, 2014 | Bissell 25A3 Proheat Upright Deep Heated...
Soap leaks thru handle
It sounds like a hose or water line has come loose.
Jul 05, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Help, how do I use this cleaner?
hit the lever on the right side that will lower the handle and clean tank
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No Water
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Bissel's Number is: 1-800-237-7691, they can tell you were to get service in your area.
Jun 23, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a bissel powersteamer and it quit spraying the solution on to the carpet... the jets are not blocked....how can i get it working again?
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. You can try putting a solution of vinegar and water, running that may clean out blockages.
Apr 24, 2008 | Vacuums
No water spray
Does water shot from the hose when you depress the trigger? If it does, then the heater in the handle may be clogged and will have to cleaned out or replaced. If no water squirts out the hose, then check the bottom of the bucket, make sure the gasket or seal is on the auto-load on the bottom of the bucket and not in the hole. The red flow indicator cap may be loose or leaking air. Could have a clogged or pinched water line under the top housing.
Jan 31, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
No water or soap flow
Does liquid squirt out of the hose. If it does then probably the heater inside the handle asm. is clogged. Take out the two long screw that hold the top handle on and remove it, then near the bottom of the handle, near the bottom are 2 more screw to remove. Then the front of the handle asm. will come off, pull the 2 tubes off of the heater and check the inlets to make sure they are open. It gets clogged up from calcium from saop deposits, but when you are down with the machine, run vinegar and water mix thru to clean out the lines before you put it away. Let me know if this doesn't fix your problem.
Jan 01, 2008 | Bissell 1699 ProHeat Clear View Upright...
Water
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
That red thing is most likely the float asm Part #2140325 .
Oct 17, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
136 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
