Question about Miele Rotary B890 Iron
Hot plate does not lift
When the foot plate is depressed the heater plate goes dow on the roller, but when the foot switch is released the heater plate does not go up. can anyone help with a solution. Thanks
0 characters
1 Points
My Meile B890 Heat plate is not heating up. can any one help
Miele 890 User Manual
maybe a simple thermostat or overheat safety switch off problem
Jul 31, 2016 | Irons
Oliso auto lift not retracting
Its can be your switch inside it so you have to strip it and cut it out its a small its like a resistor you can brigde the wires its also fine or you can go and buy a new one and put it again but you will need to solder it back
Sep 12, 2014 | Irons
Why won't the brush roller move when switch is on or off?
Sound s like the brush roller is bad and or the belt is broken. Most models have either screws or clips, that release the cover and you can cleaner the brush, and check the 2 bearings on each end. Also you will see the motor and the belt. My guess is theres where your problem lays.
Aug 24, 2014 | Shark Navigator Lift-Away Professional...
Its a Miele Rotary B890D model, when appliance is switched on the heater plate moves up and down (automatically)without the foot pedal being pressed, seems to be that the foot pedal is stuck in a pressed...
I am by no means an expert. I have an electronic background. I have been looking at my mother in laws iron and noticed a few things about it. Check the foot pedal switch. it is easy to acess. Lay machine on its back and remove the two screws and the cover. If you have a continuity test just make sure the switch changes states when you push it. Hope this helps
Mar 03, 2014 | Miele Rotary B890 Iron
Filter light flashing what do I need to do no manual available
Breville VIN170 Extreme Steam Digital Steam Generator Iron
unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
Hot Iron / Plastic Rollers On Stand
It depends on what plastic the rollers are made of. This product has alot of bad reviews on several web sites. If the reviews are anything to go by, I would be worried about the plastic rollers.
Sep 10, 2009 | Oreck Irons
Singer Steam Press PRO9S
I have a Singer steam press Pro-9S, the top plate is loose from the screws holding the hot plate and the cover arm, I like to know how to remove the hot plate cover from the arm to tighten those screws. Thank you.
Feb 18, 2008 | Irons
Tefal Steam Generator Model 2911
Jan 28, 2008 | Tefal Ultraglide 1549 Iron
Light comes on, but iron will not heat up
Like what was posted before, the cause of the iron lights is on but the heaters are not hot is because either your heater connection is melted or rusted due to water seepage(steam irons). The lights power supply are tapped parallel to the heater supply thus lights is on. Solution is to dismantle the iron to replace the connectors or cables. Though not all iron is easy to dismantle
Nov 13, 2007 | Irons
Miele Rotary B890 Iron Logo
50 people viewed this question
Top Miele Irons Experts
Sudeep Chatterjee
Sudeep Chatterjee
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Miele Iron Expert? Answer questions, earn points and help others
