Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
My Samsung model RS267LASH has a small leak coming from somewhere on the bottom of the refrigerator. Is this normal condensation or a leak?
  • GE Master
  • 4,654 Answers
I believe it is a condensate leak. every time your refrigerator defrost the water follows a tube to a pan below the refrigerator. Im going to send you the manual and a link to click on to see what will be involved to help you resolve this, Sea Breeze
Posted on Nov 12, 2009
  • John Tripp
    John Tripp Nov 12, 2009
    Click Here for the manual=> RS267LASH
    There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
    click on link below
    and here for the instructions on how to resolve the problem=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
    And here for more help=> Sea Breeze
    And HERE=> Sea Breeze Tips
    On page 18 in the PDF manual it has the refrigerator split in half. You can see the drain tube in the drawing on both half's and back at bottom of the evaporator. The manual is very helpful and I can be also if you like. If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
    If you don't have Adobe go to adobe.com
    and download the latest version of free Adobe 9
I was wondering if you could repost the link I can't get it to load, I am having the same problem.
Posted on Jun 24, 2013
In garage/works perfectly/slow leak coming from an insulated hose that goes directly into the bottom of the freezer itself.
The hose coming from the bottom of the freezer is draining the melted water produced during the automatic defrost cycle. Usually the water is collected in a pan somewhere around the hot compressor motor so the heat can evaporate the water.
The hot copper tube by the compressor is the high pressure tube going to the condenser. The other tube going to the compressor is the return line from the evaporator and, after normal operation, is cold to the touch. It is this cold refrigerant returning to the compressor that cools the motor.
Aug 19, 2015 | Refrigerators
Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
See previous answer re drain blockages. Also check condenser clean and all fans working ok.
May 20, 2012 | Samsung Refrigerators
My fridge freezer leaks water every two to three days any ideas why?
Actually, on most Frost Free refrigerators (which are most refrigerators manufactured in the last 25 years) there should be a small "pan" underneath that "collects" condensate. This is a normal process as, every so many hours, a small heater comes on inside the freezer to "melt away" any of the accumulated frost. This frost melts and runs down a tube and then is collected underneath the refrigerator. The external fan underneath the refrigerator causes the condensate to eventually evaporate into the room air. You might be, either in a very humid environment and it can't evaporate fast enough, or more likely that you have a missing pan to collect the condensate. If it is missing, you might get lucky with finding a small "cookie sheet" that might fit underneath. Be careful though. You don't want to touch, AT ALL, any of the coils (looks like radiator screens) underneath, or the fan blades. Best bet if you are missing the condensate pan is probably to get your model number and search for parts at a local appliance parts store or online.
Dec 15, 2011 | Maytag Refrigerators
My samsung rs267lash, the coil inside the refrigerator section keep on freezing up also just under the fan and it's stoping the fan
Most likely the defrosting heating element has burnt out and needs to be replaced. I know it seems contradictory but modern refrigerators rely on a heating element cycling on a couple of times daily to keep the condenser core from freezing up.
Please rate my response.
Jan 15, 2011 | Refrigerators
Samsung frig is leaking water at the bottom - it does not appear to be leaking from the inside because it is dry, but from somewhere internally at the bottom. What would cause this? The temperature...
SMALL PLASTIC water pipe under front of door has joiner which changes from 8mm ? TO 10MM ? this leaked on mine and had to be replaced .any good plumbing supply shop could supply. May need to be tightned.
May 05, 2010 | Samsung RS2630AWW Side by Side...
It is leaking water out of the bottom. It does not appear to be coming from inside the fridge or freezer. It does start on the bottom on the freezer side.
Without seeing your refrigerator I can only imagine that you have a drain pan leak below refrigerator, defrost condensate drain line loose or missing the drain pan, frozen over drain opening inside rear wall of freezer or the defrost condensate line is blocked somewhere along its route to the condensate collection tray below refrigerator.
Apr 09, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaking out of unit, not out of flow tube.
Some models have a hose, some don't , maybe the drain hole it's restricted, condensor normally it's in the back of the unit, you might have to remove one of the side panels.
Dec 23, 2009 | Convair Portable Air Conditioner
We have a leak in the back bottom of our refrigerator , ice maker
You say there was a new copper line attached? I assume that this means a repair has been done. If the unit has been slightly overcharged with refrigerant, this can cause excessive condensate to build up on the return copper tubing and would then drip in the back of the fridge. Or you should check on the drainpipe which often has a drainpan built either over the compressor dome or somewhere within the compressor area. Make sure the drainpipe is not missing the pan and that the pan is not leaking.
Mar 09, 2009 | GE 17.2 cu. ft. Top Freezer Refrigerator...
Leaking water
Hi, When your fridge does a defrost cycle, the water is drained down the back..into a storage pan where it will evaporate. In your case the pan is missing or not flat...or the drain line is plugged. You will need to move the fridge from the wall, and open the bottom pannel in the back. There you should see the problem. While you are there it is a good time to vacuum and /or blow of the cooling coils for best efficiency. (I use a shop vac, which can also blow air)
Apr 21, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
408 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
