Question about Acer Computers & Internet
I have an Acer Aspire 3610 notebook. When I try to write to a DVD, a message appears that there is no dvd device fount. It will play cd's and dvd's, write to cd's, but will not writed to dvd's. Any solution to this? Thanks, R Flater
  • papagt Nov 12, 2009
    Hawk...
    Thanks for your response. I will try your solution, then let you know the outcome. I will probably have to wait until I can get some new dvd's that you have recommended. It might take a day or so along with all of the other stuff I ahve to do!
    Thansk again,
    PapaGT
  • 855 Answers
What it sounds like you may have a player but only a burner for cd's not dvd's. You would still be able to play them just not write or record. So the first thing you need to do is check your player, if it should burn dvd's you may have to run a fix/repair program for the player or reinstall the drivers for the player. Try these items and go from there. Good Luck!
Posted on Nov 12, 2009
  • 350 Answers
If it is reading CD's & DVD's and writing to CD's it seems that your device is OK along with the drivers for it. Try using a different burning engine if you can (it may be a software issue) and I would definitely look into a different media (DVD R/W disks). Make sure that your DVD burner supports both formats of DVD's (dual format) + & -- disks and make sure you have the appropriate ones that are compatible. Try a different disk manufacturer, Memorex seems to be the worst out there. Many problems with DVD burning is usually the Media being substandard. Take a look in your device manager (right click on MY COMPUTER, go to PROPERTIES, and then DEVICE MANAGER. Look for any yellow exclamation or question marks. If present, click on it and look at the drivers for the drive. They possibly need to be updated or rolled back. Likewise, sometimes you can right click on the device (DVD/CD drive) in the device manager and uninstall it. When you reboot, Windows will detect the "new" hardware and install the proper drivers from the System folder (if they are not corrupt) and everything should be fine. Installing and uninstalling software can cause problems with devices as well. I hope this helps and good luck!
Acer aspire 3610 dvd drive does not work
Check it is "seen" in the bios first, a failed device will often disappear from the bios
Then, in My Computer, see if you can see the DVD Icon
Now If you can see it, go to Control panel, device manager and see if there is a yellow exclaimation mark next to the device, indicating a problem. If there is, the device has possibly failed, but you can try to remove the retaining screw that holds it into the laptop remove the DVD and re-insert it. This works most times IF the device still has life left in it
IF you cannot see the DVD in My Computer, repost and I'll talk you through the next stage, which involves resetting the filters in the registry
Dec 31, 2010 | Acer Aspire 3610 Notebook
I'm trying to record a DVD on the DVD/CD-RW combo recorder in my Acer Aspire laptop. When I insert a blank DVD, whether it's a R or a -R, I just keep getting the message to insert a blank DVD. How do I...
Try a different manufacturer/brand of DVD-recordable disks.
If you still have the problem, then your drive is malfunctioning,
and you need to get a qualified technician to disassemble your computer, and replace it.
Oct 09, 2010 | Acer Aspire One PC Notebook
Cd dvd dont play correctly
speed control in the unit. The DVD can't sync with the audio. It is usually a hardware problem. Need to replace the DVD drive.
Apr 26, 2009 | Acer Aspire 3610 Notebook
I can,t found cd/dvd icon in my computer And i can,t play any cd or dvd I have Notebook Acer ( aspire 5635WLMI )
This may be as simple as the fact that the BIOS settings could be set to make the drive not appear, or it could be a defective drive. Try to check your BIOS settings to be sure it is set either to "AUTO" or to the drive itself. If it is setup in bios but it does not recognize there, it is probably a defective drive. Also, check device manager in windows and see if the drive shows there. If it shows there but will not play a disc it is more than likely defective....
Mar 10, 2009 | Acer Aspire 5315 Notebook
Downloading music tracks to a blank CD using Sony Sonic Stage software
go into the settings for sonicstage and select your dvd drive. that should be it. but you may have to do other things(i have a sony player too, but i have found sonicstage to be a waste of space and time. it is rather a pain. try looking through the manual and seeing if you have any options for the location of the cs drive. if not, then get a usb cd burner and connect it to the laptop. that should work properly.
Aug 29, 2008 | Acer Aspire 3610 Notebook
The DVD works but CDs will not read
that happens with those..one function or the other bails...time for a new device in your laptop..not too much money, nor hard to replace.
check your computers warranty here 4 FREE
Mar 19, 2008 | Acer Aspire 3610 Notebook
Dvd/cd rom not working
can u reset the dvd rom drive in the system does it pull out can u psuh it back in on side whole unit justto make sure pushed in all way could be broke u can get one on ebay cheap
Jan 13, 2008 | Acer Aspire 3610 Notebook
Aspire 4520 DVD combo problem
Try to clean your combo head with spirit using cotton...thats all..
Dec 12, 2007 | Acer Aspire 5610-4648 Notebook
Cd/dvd drive
your cd rom is brike you need to buy a new one
Nov 27, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
