Question about Microwave Ovens
When drying cycle is set on timer.circuit breaker trips Timer has been replaced but don't know if it is good. shipped with no packing or paperwork from Sears There is 2000 ohm short between the black power lead and ground until the door is opened or the timer moved to off.
  • 155 Answers
If you are sure you have wired the timer correctly you may have a faulty element as to the short between your black wire and ground are you checking this with the dryer disconnected from wall socket also run the dryer on cool if does not trip the power element faulty if it still trips you may have a wiring problem and you will have to check further let me know how you go
Posted on Nov 12, 2009
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
Apr 14, 2014 | LG LMV1813ST Microwave Oven
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
Timer runs 10 times speed
Try to power by locating circuit breaker that powers that area?
Nov 05, 2012 | KitchenAid KCMS2055SSS Microwave Oven
The trip breaker in my home for the electrical outlet keep tripping off what do i do. the breaker in my electircal box for my electrical socket keep tripping off
go to the qualified electricians on your place... but there is some helpful tips that can help you.. (1) for continued protection before starting. turn off the main circuit breaker. (2) unplug all the appliances or equipment installed... (3) check all the wall socket outlet... look for any damages on the wall socket... if the wall socket outlet have no signs of burned or wet marked, try to turn on the circuit breaker. check if the problem is solved.. (4) if the wall socket outlet have a signs of burned or wet marked.. just replace that w/ the same type of socket... check also the appliances that may caused the problem... the easiest way to know is to look at the socket plug itself... ty
Jun 21, 2011 | Microwave Ovens
During the cooking for our Christmas dinner the temperature started declining from the 350 degrees to 280 degrees. We tried the top burner to make sure the stovetop was working and the whole thing shut...
Hi Jane,
Ouch! Sorry about the Christmas dinner. I sounds as though the circuit breaker tripped.
First, find the circuit breaker panel.
1 Check to see if a breaker has tripped. These breakers are double sided because stoves are
240 volt appliances, like the water heater or the house heater. There is a bar that connects
two single breakers together. The breaker will be slightly off center to the other breakers if it is tripped.
2 If it HAS tripped DON'T TURN IT ON YET
3 Go back to the stove and plug it in.
4 Turn on a top burner(not the one that may have tripped the breaker) preferably one that you know works that you don't use very much.
5 Go back into the garage and turn on the breaker.
6 If it goes on OK go back to the kitchen. You have done the first diagnostic test.
7 Check the burner to see if it is getting hot. If it is, turn it to high and then turn on the burner that blew the breaker in the first place. See if it blows the breaker again. If it does not. Turn on all of the burners that you know work. You have now done several Diagnostic Steps that are important.
8 If one of the burners trips the breaker, you have one of the culprets. If not, GREAT.
9 Shut off all of the burners
10 DO NOT TURN ON THE OVEN
11 Open the oven door and look very carefully with a flashlight at the bottom bake heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced.
12 There is one other rare possibility, but it would not have blown the breaker. Many ovens have clock baking timers. These timers will, shut down the oven. If someone adjusted the timer and didn't turn the knobs in the exact right position. It will ruin the party shutting down the oven at the worst time. But it won't shut the stove top burners down.
IF YOU HAVE FUSES INSTEAD OF BREAKERS
If you have fuses instead of circuit breakers, Find several of the large cylinder shaped fuses to conduct the diagnostic tests I suggest. They are usually available at home depot.
RARE PROBLEM
One last but very rare occurence with breakers is their specifications sometimes change over a long period of time. If that is the case, they will trip and lower and lower overload levels. Simply Replace.
I hope this helps,
Good Luck
Best Regards,
Mark
Dec 29, 2010 | Microwave Ovens
Bravetti Toaster Oven -- Purchased, December 2008. Timer is not working. Can I buy a new one? I also need the knob as in the process of determining why it would not heat, the know was broken in order...
The only way to get OEM parts for that is to
Contact Euro-Pro by phone at (800) 798-7398. I called them and they do not sell internal parts for their products, but they will fix it for you for $27.00 plus $16.95 shipping, maybe the shipping to you would be less. You must pay for the shipping to them as well.
Other then that you will have to replace it..
Sep 15, 2010 | Microwave Ovens
Whirlpool Range RF315PXDW. Electric range. Top burners and oven will not turn on. Clock on top of stove and oven light turn on. Oven preheat timer operates but heating elements in oven do not turn on....
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Dec 19, 2009 | Microwave Ovens
When cycle is set and start button push. the cycle (timer) switch just buzzzes but the washer does not operate
HI. The timer control module will be the culprit here. The buzzing is a very strong indication of circuit failure. This will require you to replace this damaged device. Once replaced, the unit will be able to operate at its normal capacity.
Dec 08, 2009 | Microwave Ovens
Even though timer starts the microwave doesn't start cooking
read this post
Parts:
magnetron: W10131681
HV capacitor: 815124
HV diode: W10201950
HV transformer: 8171873
Of note: generic parts are cheaper and will work as well.
Oct 20, 2009 | Whirlpool GH7155XHS Microwave Oven
ALL POWER LOST
I am not sure I can solve your problem or perhaps you have already solved your problem. My thought is "are you sure your circuit Breakers are OK"??? In order to re-set a tripped circuit breaker you have to first turn them all the way off, then re-set them to 'on'. If you did not do that they probably did not re-set.
Assuming you did that correctly then I would have to suggest you contact prototech@usa.net. He/they might know of a internal fuse or other problem the may help you. Good luck.
****.sue@hotmail.com
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
