Question about Westinghouse (78060) 30" Princess Radiance Polished Brass Ceiling Fan
This has worked almost three years with the energy saving bulbs. Began flickering about a week ago, and then tonight two of the bulbs went out. replaced them with regular bulbs (75watt each). Now very dim- lights aren't lighting to full extent. ??? Also, those other bulbs should have lasted a few more years.
  • Westinghouse Master
  • 43,501 Answers
There is a bad or poor connection where the house wires hook to the fan wires.
Posted on Nov 12, 2009
I change my bathroom vent light. Before light went out. When I would turn the light on. It just came on. Now with new light, it flickers then comes on. And my hall bathroom started doing it too once I...
It sounds like you have indeed bought fluorescent bulbs. manufacturers are encouraged to replace the incandescent bulbs with more energy saving fluorescent bulbs. They are made to look like standard bulbs so you need to look at the package carefully to see the difference. The Nu Tone and other special bulbs may still be available in the old filament style for a while but you may have to look harder or ask if they are still available. The amount of flicker often reflects the quality of the bulb. It will sometimes decrease over time.
Mar 02, 2015 | Dryers
Would it be anormal for all three to go out at once and everytthing else work? it was all fine earlier except a few times it has been flickering in the car, i thought it was the battery and we changed that...
Something is draining the battery. Is there a light on in the trunk? See if you trunk is fully closed and the light is going off, or remove the bulb and see if that helps.
Dec 05, 2013 | 1991 BMW 3 Series
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
We have a 2 year old Hunter Fan Model # 23285 The fan works fine. Last week the lights began flickering. We changed bulbs, checked for loose wires, etc. The lights go on dim and continue to flicker. ...
if problems with lights flickering. remove governor inside for the lights, and wire lights direct. this should cure problem. ( black box or governor ). part # 98480-02-- have a good day !!
Jan 06, 2011 | Hunter Ceiling Fans Individual...
I need to be able to send pictures again as i was up untill approx two or three weeks ago. About then out of the blue microsoft office email progam appears when i try to send a picture but i canot send...
When in IE > Tools > Internet Options > Programs tab > In Internet Programs section what do you have as Email program?
Can you select "Outlook Express" in Drop-down menu of Email option?
Try setting OE and score this solution.
Nov 15, 2010 | Microsoft Office Outlook 2003 for PC
One of my five EJ500C timers controls 6 outdoor landscaping lights behind my house. I installed the energy saving (coil type) bulbs and, at roughly 15 minute intervals after the lights come on at dusk, the...
The EJ500C is designed only for standard incandescent lights, not chandelier bulbs, CFLs, etc. Replace it with the ST01C, and you'll be fine. Intermatic may even exchange it for you if you if you complain to them.
Feb 27, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
My screen acts as if it's on energy-saving-mode but doesnt activate...
Check and reset the Screen Saver to the settings you want, even if its set properly. Did this work?
If not, reset the monitor to factory defaults to flush its memory.
If that doesn't work unplug the monitor for a minute and replug.
Sep 02, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Mar 11, 2008 | Dryers
Fluorescent light that keeps flickering
The ballast is a device that utilises and expanding/contracting electromagnetic field to create the high voltage which is needed to run fluorescent lights.
It is normally found behind the front cover or reflector part of the fitting and looks like a small box.
Replacement should normally be done by a person qualified in this field.
Oct 26, 2007 | Sea Gull Lighting Sea Gull Energy Saving...
Westinghouse (78060) 30" Princess Radiance Polished Brass Ceiling Fan Logo
100 people viewed this question
Top Westinghouse Dryers Experts
stevensmn
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
